Using sleep function with Panels
andrea.darlington
I'm writing a function to give the user a simple alert in my functions. I would use DoAlert for this but I don't want them to have to click anything. I'd like a message to popup on the screen, stay there for a couple of seconds and then be closed automatically. Right now I've come up with the code below but when I run it I don't get the behaviour I'm expecting. It seems to open the panel, run the sleep command, and then load the titlebox command. I start out with a blank panel for a second or two then the text briefly appears before the window is killed again. Should I be using a different function for this?
Function procComp(atext) String atext NewPanel /W=(911,369,1311,505)/N=Alert TitleBox title0,pos={105,54},size={181,21},title=atext,font="Arial",fSize=18,frame=0 sleep/s 2 KillWindow Alert End
Thank you!
Andrea
DoUpdate/W=Alert
August 9, 2017 at 08:21 am - Permalink
August 9, 2017 at 08:23 am - Permalink
