I am having some trouble with the code that I wrote in which I'd like to concatenate waves that are from a wavelist into a new destination wave. Maybe it's something about the syntax that I am missing? Some of these waves have NaN values which I'd like to preserve in the final concatenated waves.
The NaNs are not the problem. Your problem is the overwrite flag in Concatenate. The code repeatedly concatenates just one wave into the destination and overwrites it. Actually, if you check the help for Concatenate, you can supply a semi-colon separated string list in a one-liner to do what you are trying to do.
Actually another problem is the way that your loop is written. The limit is should be i = endnum. As written the loop won't execute the first time since 0 is <= endnum.
July 28, 2017 at 02:35 pm - Permalink
July 28, 2017 at 04:08 pm - Permalink
July 30, 2017 at 05:00 am - Permalink
August 1, 2017 at 08:07 am - Permalink
