JimProuty There is a function named "WaveMax": Print WaveMax(dataWave) --Jim Prouty Software Engineer, WaveMetrics, Inc. Log in or register to post comments July 12, 2017 at 11:58 pm - Permalink
sjr51 You can also execute WaveStats dataWave to display a range of info in the history window, including the maximum value (V_max). Log in or register to post comments July 13, 2017 at 01:00 am - Permalink
TRK JimProuty wrote: There is a function named "WaveMax": Print WaveMax(dataWave) --Jim Prouty Software Engineer, WaveMetrics, Inc. TRK Great! Thanks Jim. Log in or register to post comments July 13, 2017 at 06:16 am - Permalink
TRK sjr51 wrote: You can also execute WaveStats dataWave to display a range of info in the history window, including the maximum value (V_max). TR This function has a lot of info about the wave. For only executing the maximum value, print command is the best. Thanks a lot sjr51. Log in or register to post comments July 13, 2017 at 06:20 am - Permalink
WaveStats dataWave
to display a range of info in the history window, including the maximum value (V_max).July 13, 2017 at 01:00 am - Permalink
TRK
Great! Thanks Jim.
TR
Thanks a lot sjr51.
