delete points
I wondering if somebody could help me,
I need to remove three lines for interval, example: for 4 lines i need to remove 3 leaving 1 intact
thanks so much
I hope I understand you right: You would like to delete every 3 rows/lines out of 4, right? Here is code which deletes all rows besides every nth row:
Function Deleterows(data, every)
    Wave data       //input data
    Variable every      // which nth line to leave
    Variable i
    Variable iteration = floor(Dimsize(data,0)/every)
    Variable overhead = Dimsize(data,0) - iteration*every
    for (i=0; i< iteration; i+=1)
        DeletePoints i,every-1, data
    if (overhead)
        DeletePoints i,overhead, data
Now you just need to input into the command line:
Deleterows(yourdataname, 4)
Hope that helps. If you would like to know more about the used commands, just take a look into the help browser.
    Variable i
    if (overhead)
Thanks so much it works very well!!
Another way to accomplish this is illustrated here:
make junk=p      // make a fake data waveMake/D/n=(numpnts(junk)/4) reduced_junk
•reduced_junk = junk[4*p]
This has the potential advantage of preserving the original data. It also may be faster because it avoids using an explicit loop. I have not tried comparing timings.
I bet AG comes through with a clever way to use MatrixOP...
How about this for extracting a reduced set of the wave into a sparser wave, rather than deleting points:
function sparse(data, every)
    wave data
    variable every
    extract data, wsparse, mod(p,every)==0
The new destination wave 'wsparse' is specified and created in the 'extract' command, but could easily be converted to an input specification.
Just a small comment on deleting points in a wave or characters from a string:
Work through the data backwards ! It avoids to move points-about-to-be-deleted several times and can be MUCH faster (from waiting 10s to "instant")
for (i=iteration; i>=0; i-=1)
(adjust the limits)
HJ
