imaginary part is missing
after performing sf_calc(), imaginary parts of F_Ni, F_NiO1.... is missing (imaginary parts are 0). Q_x is real number in 0.1 < Q_x < 5
Function SF(occ, ASF, xx , z, u)
    wave ASF
    variable occ, xx, u, z
    variable/c ci = sqrt(-1)
    variable/c rtn = (occ * ASF * exp(ci*xx*z)*exp(-0.5*(xx*u)^2))
    return rtn
Function SF_calc()
    ASF_calc()
    wave Q_x
    wavestats/q Q_x
    variable/g u_res
    u_res = 1.1 / V_max
    variable/g u_Ni, u_Ni_eff
    u_Ni = 0.5
    u_Ni_eff = sqrt(u_res^2 + u_Ni^2)
    variable/g u_O, u_O_eff
    u_O = 0.1
    u_O_eff = sqrt(u_res^2 + u_O^2)
    //UNIT CELL AND CTR //
    Make/O/C/N=(numpnts(Q_x)) F_Ni, F_ctr
    wave ASF_Ni, ASF_Ni2, ASF_O
    F_Ni = SF(uc_occ, ASF_Ni, Q_x, d_spacing, u_Ni)
    F_ctr = 1 / (1-exp(-ci*Q_x*d_spacing))
    //PASSIVATED NiO LAYER//
    Make/O/C/N=(numpnts(Q_x)) F_NiO1, F_NiO2, F_NiO3
    variable/g gap1, gap2, gap3
    gap1 = d_spacing
    gap2 = d_spacing
    gap3 = d_spacing * 1.1
    F_NiO1 = SF(2, ASF_Ni, Q_x, gap1, 0.5)
    F_NiO2  = SF(2, ASF_Ni, Q_x, gap2, 0.5)
    F_NiO3 = SF(2, ASF_Ni, Q_x, gap3, 0.5)
    Make/O/N=(numpnts(Q_x)) I_tot
    I_tot = magsqr(F_Ni*F_ctr + F_NiO1 + F_NiO2 + F_NiO3)
    Make/O/N=3 coefwave
    coefwave[0] = gap1
    coefwave[1] = gap2
    coefwave[2] = gap3
See the reply that I gave in your other post. You must do what you want ONE STEP AT A TIME. Your complex and long code has far too many basics mistakes to debug properly.
One of those basic mistakes is that a complex function must be declared with /C: Function/C SF(occ, ASF, xx , z, u). The /C flag tells Igor's compiler that the function returns a complex number.
I would also recommend reading the Programming help a few times. Each time through you will retain a bit more. The first time through a manual like the Programming help it is very hard to put together a coherent impression of the contents.
