Iterating a curve fit in a varying range
remolorio
I have correlated a Raman spectrum with itself (autocorrelation, see attachement). I now would like to fit a gaussian curve to the central peak of the resulting wave. This should be done multiple times for a varying range of X_values (say from -20 to 20, -19 to 19, -18 to 18, etc. to -2 to 2).
The Gaussian function looks like this: gaus=w[0]*exp(-((x-w[1])/w[2])^2), with w being the coefficient wave, and x the variable. I suppose using the FuncFit operation?
The values of w[2] of all fits should be stored in one result wave.
How can this be done? Ideally there is a certain flexibility for the boundaries and increments chosen, depending on the case.
I am a beginner and this is beyond my programming skills.
Thanks
Remo
Fitting with an x-range of -2 to 2 will use three data points.
Do you actually want to perform a deconvolution of your AC into three peaks? Have a look at the multi-fit package (in the Analysis menu).
HJ
June 7, 2017 at 12:35 pm - Permalink
June 7, 2017 at 02:20 pm - Permalink
CurveFit gauss Auto_corr[pcsr(A),pcsr(B)] /D
and replace "pcsr" by your range (in data points)If you want to automate it, have a look at the manual regarding loops:
displayhelptopic "loops"
However, it seems that the result for a narrow range is quite similar for the result from the deconvoluted peaks. It sounds to me like this method is some kind of approximation (eliminating overlapping sidebands -- I haven't read details, I admit -- just my feeling).
Have a look at the attached image. The black bold line is the center peak from a multi peak fit (middle graph; AC data as '+') and it looks like the original signal in the range of approximately (-7 ...7).
HJ
June 7, 2017 at 03:46 pm - Permalink
The option proposed by @HJDrescher to peak fit and thereby resolve (and apologies but ... speaking strictly and pedantically, deconvolution is an improper term here) the components to the broad peak may also miss something fundamental that is determined by the approach you want to take. We'd need to see a reference otherwise.
Finally, I would be surprised when the approach that you propose does not lead to a "step-function-like" plot of half-width versus fit range. At the largest fit range, the peak width will be consistently broad. At some range, the width with snap-down to the narrow peak. At some final range, the width will essentially snap-down to the step size between points. Again, a reference to see where what you want to do has been applied (successfully) somewhere else would help.
ps ... Yes, what you want to do can be programmed to be a routine that you can run automatically. Further recommendations may follow later.
June 8, 2017 at 05:50 am - Permalink
I have attached an article describing this approach. The main recipe is on pp508.
I have invested a few hours and tackled this problem myself. The whole thing is a patch work of snippets and adaptions thereof from stuff I found.
It seems to work in principle, although I do get "out of range" errors at the end. The Aim is to be able to select any subrange of the input wave and perform the analysis. The Value of interest eventually is y of x=0 of the polynomial fit to the various gaussian widths.
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
Macro AutoCorrelation(scrwave)
string scrwave,subrange,prefix,bline,k0_coef,k0_coef_sigma,Dcorr,Dcorr_sigma,autocorr
Prompt scrwave,"Spectrum to analyse",popup Wavelist("*",";","") //select source wave, subrange, and lable in pop-up menu
rangeinput()
subrange=lable+"_range_"+scrwave
bline="bl_"+scrwave
autocorr=lable+"_autocorr_"+scrwave
k0_coef="k0_"+lable+"_"+scrwave
k0_coef_sigma="k0_sigma_"+lable+"_"+scrwave
Dcorr="Dcorr_"+scrwave
Dcorr_sigma="DcorrSigma_"+scrwave
make/N=0 $k0_coef
make/N=0 $k0_coef_sigma
make/N=0 $Dcorr
make/N=0 $Dcorr_sigma
duplicate/O/R=(gX1,gX2) $scrwave,$subrange //Duplicate a subrange of the source wave, specified by x-value
duplicate/O $subrange,$bline
Variable x1,x2,y1,y2
x1=leftx($subrange)
x2=rightx($subrange)
y1=$subrange[0]
y2=$subrange[numpnts($subrange)-1]
$bline= ((y1-y2)/(x1-x2))*x+x1*y2
$subrange=$subrange-$bline
duplicate/O $subrange,$autocorr
Correlate/AUTO $subrange, $autocorr
GaussIteration(max_deltaw,increment,$autocorr,$k0_coef,$k0_coef_sigma)
CurveFit poly 3, $k0_coef[start_xtrp,max_deltaw] /F={0.95, 4} //fit the widths of the Gaussian curve fits ("$k0_coef") by poly3
Variable Dc
Dc = W_coef[0]
Redimension /N=(numpnts($Dcorr)+1) $Dcorr
$Dcorr [numpnts($Dcorr)] = Dc
Variable Dc_sigma
Dc_sigma = W_ParamConfidenceInterval[0]
Redimension /N=(numpnts($Dcorr_sigma)+1) $Dcorr_sigma
$Dcorr_sigma [numpnts($Dcorr_sigma)] = Dc_sigma
Function GaussIteration(plusminusX,incrementX,ywave,output,output_sigma)
variable plusminusX,incrementX
wave ywave, output, output_sigma
variable i
for(i= 3; i<=plusminusX; i+=incrementX)
CurveFit/Q gauss ywave((-i),i) /D
Wave W_coef, W_sigma
Variable k0
k0 = W_coef[3]
Redimension /N=(numpnts(output)+1) output
output [numpnts(output)-1] = k0
SetScale/P x 3,incrementX,"", output
Variable k0_sigma
k0_sigma = W_Sigma[3]
Redimension /N=(numpnts(output_sigma)+1) output_sigma
output_sigma [numpnts(output_sigma)-1] = k0_sigma
SetScale/P x 3,incrementX,"", output_sigma
<pre><code class="language-igor">
EDIT: here is a tidier version of my macro
June 9, 2017 at 04:28 am - Permalink
I cannot comment directly now on improvements to what you have but I do want to follow up once my schedule permits.
June 8, 2017 at 11:37 am - Permalink
Eventually, I'd be interested to expand this to a method to do the entire analysis starting from a spectrum input. That's going to take a bit more though.
June 9, 2017 at 12:46 pm - Permalink
when it does the gaussian fit to a subrange of the auto_corr wave, it fits a value for y0. In the orignal procedure proposed in literature however the gaussian fit is done always with y0 = 0.
I have tried to implement this behaviour in my own attempt by defining K0=0 and add the flag /H="1000", which corresponds to y0 for a gaussian curve, this seems to work, however there is an ugly step in the resulting fit curves. How would you do this?
here is my humble try
string graphname
variable i
variable y0=0
K0 = y0
Display /N=graphname
for(i= 15; i<=plusminusX; i+=incrementX)
String Gauss_fit=graphname+"_"+num2str(i)
Duplicate/O ywave, $Gauss_fit
CurveFit/Q/H="1000" gauss ywave((-i),i)/D=$Gauss_fit
Variable width
width = W_coef[3]
output [numpnts(output)-1] = width
SetScale/P x 15,incrementX,"", output
Variable width_sigma
width_sigma = W_Sigma[3]
output_sigma [numpnts(output_sigma)-1] = width_sigma
SetScale/P x 15,incrementX,"", output_sigma
appendtograph /W=graphname $Gauss_fit,ywave
June 11, 2017 at 09:19 am - Permalink
* Write the exponential function as a self-made fitting function where y0 is absent. Fit to the home-made function instead of the in-built gauss function. This avoids the need to use a HOLD wave or coefficient term.
* Write the procedure so that it can be added by an #include statement and works on a wave in the front-most graph. This will make the package portable. You will be able to generate auto_corr waves from spectra, store them in specific folders, #include the correlation analysis package, run it on the different auto_corr waves in different graphs, and obtain the output values of correlation value versus step size.
On the front end ... loading and correlation analysis of the spectra are left to you or to a much later project. On the back end, to save analysis results as independent experiment sets, I recommend the SnapIt Package found here http://www.igorexchange.com/project/SnapIt.
So, for the next step, here's what you might do. Write a GaussFixedPosition function to replace the built-in Gauss function. Modify the line in the code I provided to use FitFunc with the modified GaussFixedPosition function instead of CurveFit with the built-in Gauss function. I'll wrap the functions provided in a UI panel that works on a wave in the frontmost graph (much like the SnapIt package works on waves on the frontmost graph).
June 12, 2017 at 09:50 am - Permalink
June 16, 2017 at 12:34 pm - Permalink
Here's my procedure file. It hasn't been tested much, but worked when I used it for some Raman and IR spectra.
June 21, 2017 at 01:44 pm - Permalink
