function like accumarray or bincount
Does Igor have a function like MATLAB's accumarray or numpy's bincount? I essentially want to accumulate the values of 2D (complex) wave A into a 1D (complex) wave B according to indices in wave C. Therefore, wave A and wave C have the same dimensions. I have implemented this using a nested for loop, but it is somewhat slow. MatrixOp wavemap only seems to be able to sort a 1D wave into a 2D wave from the description?
function map()
    make/O/C/N=(128,128) gauss_wave = 0
    make/O/N=(128,128) map_wave = 0
    gauss_wave += cmplx(exp(-(x^2+y^2)/8192), 1-exp(-(x^2+y^2)/8192))
    map_wave = round(sqrt(x^2+y^2))
    make/O/C/N=(wavemax(map_wave)+1) accumarray
    variable i,j, index
    for(i=0; i<128; i+=1)
        for(j=0; j<128; j+=1)
            accumarray[map_wave[i][j]] = gauss_wave[i][j]
Is there any way to use MatrixOp or otherwise speed this up?
I guess your problem sizes are larger than the example? The example is already quick here.
Before we start optimizing the code. Does the code really do what you want?
The problem is symmetrically in i and j so I would have expected something like
accumarray[map_wave[i][j]] += gauss_wave[i][j]
as you otherwise overwrite values in the accumulation array.
Does this not work to eliminate the loops (or am I confused by something otherwise obvious on this late Thursday after a long day)???
accumarray[map_wave[][]] = gauss_wave[p][q]
Thomas, you are correct I left out the accumulation. J.J., your code would work, but I need to accumulate the values into the new array, not overwrite them as Thomas pointed out. The following code does exactly what I need:
function map()
    make/O/C/N=(wavemax(map_wave)+1) accumarray = 0
    make/O/N=(wavemax(map_wave)+1) accumcount = 0
    variable i,j, index
            accumcount[map_wave[i][j]] += 1
    MatrixOp/O accumarray = accumarray/accumcount
Using the MSTimer, this code takes about ~13 ms. I don't have access to my matlab setup right now but I believe the code runs in less than 1 ms. I will double check and get back.
Would this improve with threading?
Would this improve with some other implicit indexing trick (by example admittedly off the top of my head ...)?
make/N=128 iwave
make/N=128/D gwave
for (i ...)
       iwave = map_wave[i][p]
       gwave = gauss_wave[i][p]
       accumarray[iwave] += gwave[i]
I'm not sure about threading but it should work better with MatrixOP WaveMap(). What may not be so obvious is that waveMap() works with 1D, e.g.,
make/n=10 ind2=10*(p+1)
make/n=4 ww={2,5,8,9}
matrixop/o aa=waveMap(ind2,ww)
In the case of the code above, there is no obvious reason why one can't execute:
    Duplicate/o map_wave,map1d
    Duplicate/o gauss_wave,g1d
    Redimension/n=(128*128) map1d,g1d
or possibly just redimension the original waves (faster).
