Possible bug (?): AxisValFromPixel
_sk
Consider the following snippet:
function thunk_do()
make/o/n=100 a = gnoise(100)
make/o/n=50 b = gnoise(100)
string s_name = ("Graph" + hash( date()+time(),1 ))[0,30]
display/k=1/n=$s_name b vs a
setwindow $s_name, hook(modified)=thunk_hook_onmodify
function thunk_hook_onmodify(s)
struct WMWinHookStruct &s
strswitch(s.eventname)
case "mousemoved":
string s_pixel_y
string s_pixel_x
sprintf s_pixel_y, "%d.%d", s.mouseloc.v, s.mouseloc.h
sprintf s_pixel_x, "%d.%d", s.mouseloc.h, s.mouseloc.v
variable v_y = AxisValFromPixel(s.winname, "left", str2num(s_pixel_y))
variable v_x = AxisValFromPixel(s.winname, "bottom", str2num(s_pixel_x))
printf "coords (y,x): (%3.3f,%3.3f)\r", v_y, v_x
break
case "kill":
setwindow $s.winname, hook(modified)=$""
break
endswitch
case "mousemoved":
string s_pixel_y
string s_pixel_x
break
case "kill":
break
endswitch
and specifically, the following lines:
While not the most elegant way of getting a pixel, both
s_pixel_y
and s_pixel_x
are needed as AxisValFromPixel
does not return the expected value for the "same" pixel applied to a different axis.Put simply, is this a bug or "desired behaviour"™?
Btw, is this the best way of getting/representing a pixel? Seems rather odd if it is.
best,
_sk
v_y = AxisValFromPixel(s.winname, "left", V_top)
v_x = AxisValFromPixel(s.winname, "bottom", V_left)
printf "mouse (y,x): (%3.3f,%3.3f)\r", v_y, v_x
March 10, 2017 at 02:30 am - Permalink
Thanks, but
getmouse
is unnecessary. The mouse location is already in the event structure as indicated above, namely:s.mouseloc.v, s.mouseloc.h
I was asking why
axisvalfrompixel
doesn't use the same pixel as represented by:variable v_pixel = str2num(s_pixel)
to get the values from both axis? It is the same pixel whichever way it is "represented". To me, it seems like the logical thing to do. And the best thing to do would be for
axisvalfrompixel
to just use the struct of the event,s.mouseloc
, thus:variable v_x = axisvalfrompixel(s.winname, "bottom", s.mouseloc)
March 10, 2017 at 02:55 am - Permalink
March 10, 2017 at 03:50 am - Permalink
case "mousemoved":
variable v_y = AxisValFromPixel(s.winname, "left", s.mouseloc.v)
variable v_x = AxisValFromPixel(s.winname, "bottom", s.mouseloc.h)
break
case "kill":
break
endswitch
If you're calling AxisValFromPixel with a vertical axis (left or right), you only need to pass the vertical value of the pixel. Likewise, with a horizontal axis (top or bottom) you only need to pass the horizontal value of the pixel.
March 10, 2017 at 06:15 am - Permalink
Yes, of course this is going to work. My point is that the user of the
AxisValFromPixel
function shouldn't need to specify twice which value needs to be return: first time with the axis ("bottom", "left") and second time with the offset ("horizontal", "vertical"). If the functionAxisValFromPixel
knows that the user is passing the "bottom" axis (or axistype is bottom), I think only values with respect to this axis can be calculated. Respectively, only a particular value of the mouse position is needed, but this value is predetermined by the axis alone. Thus my suggestion for passing the struct,mouseloc.v, mouseloc.h
. On top of that, a common consumer forAxisValFromPixel
are event loops, and in this casemouseloc
is already a substruct of the event.A second point is that this is not a pixel, as suggested in the documentation, but the _offset distance_ of the mouse cursor (either horizontal or vertical) with respect to the window top-left corner.
Anyways, I hope somebody finds all of this helpful.
best,
_sk
March 10, 2017 at 06:55 am - Permalink
I agree that the wording of the AxisValFromPixel help topic is a little vague.
March 10, 2017 at 07:44 am - Permalink
I didn't know. Anyways this is the least important thing.
Why do you say that? I think this isn't right. You pass the point struct and depending on the axis you selected you return the value for that axis. Simple as that. What you gain is that you don't need to memorize which value you pass as the offset, the proposed axisvalfrompixel does that for you.
How is this different from the way it is now?
Anyways, the discussion is moot. Thanks again for the help.
best,
_sk
March 10, 2017 at 08:48 am - Permalink
