Data Browser: optional echoing of Custom Commands
harneit
ModifyBrowser
, Igor echoes the generated intermediate command to the command history. This can be annoying if one tries to use the DataBrowser as an input device (see this forum contribution). A possible solution is to add a choice to put this echo On/Off via the "Preferences" button in the DataBrowser.
When you set up your interface execute the command:
ModifyBrowser echoCommands=0
This should eliminate the printing in the history when you use "Execute Cmd...".
January 4, 2010 at 09:33 am - Permalink
I fed your answer back to the original forum topic.
Wolfgang Harneit
January 4, 2010 at 11:39 am - Permalink
