Graph mode "Arrow to next"
joerg.kunze
I always struggle around, if I have to use arrows in graphs. Up to now, the only way seems to be a tag. But in a tag you cannot exactly definie length and direction of an arrow. So the easiest thing would be to be able to place a trace on a graph that draws an arrow to the next data point. Then I can define arrows from traces. And I can also draw directional graphs on maps etc...
Best regards,
Joerg.
Basically, you create a marker wave defined by the points you want to connect.
February 28, 2017 at 09:21 am - Permalink
For more information, execute the following command on Igor's command line:
Then scroll down a bit to the arrowMarker keyword. There's also a textMarker parameter which might be of some use.
February 28, 2017 at 09:22 am - Permalink
