How to duplicate a wave or matrix by a provided name using function??? [SOLVED...]
I am new in Igor. I am trying to plot an image after doing an operation of the given matrix.
I have written an function and it works perfectly...where I have a fixed name of the new matrix.
Function PlotRelAnisotropyImage()
    wave matrix
    Display;DelayUpdate
    AppendImage matrix;DelayUpdate
    ModifyImage matrix ctab= {-6.13085,0.465855,VioletOrangeYellow,1};DelayUpdate
    Label left "Polarizer Angle (Degrees)";DelayUpdate
    Label bottom "Wavelength (nm)";DelayUpdate
    Duplicate matrix, RelAnisotropy
    Variable numRows = DimSize(matrix,0)
    Variable numColumns = DimSize(matrix,1)
    Redimension/N=(numRows,numColumns) RelAnisotropy
    Variable i,j,k
    for(i=0; i<numRows; i+=1)
        for (j=0; j<numColumns; j+=1)
            k = (j*5)+90
            if (k>360)
                k = k-360
                k = k
            RelAnisotropy[i][j] = matrix[i](j*5) - matrix[i](k)
    Display;DelayUpdate
    AppendImage RelAnisotropy;DelayUpdate
    ModifyImage RelAnisotropy ctab= {-4.82601,0.74151,VioletOrangeYellow,1};DelayUpdate
Now, at time of calling the function, I want to provide the name of the new matrix. How can I do that...???
I have tried in the following way... but getting many errors...
Function PlotRelAnisotropyImage(MatrixName, NewMatrixName)
    Wave MatrixName
    String NewMatrixName
    Display;DelayUpdate
    AppendImage MatrixName;DelayUpdate
    ModifyImage MatrixName ctab= {-6.13085,0.465855,VioletOrangeYellow,1};DelayUpdate
    Duplicate MatrixName, $NewMatrixName
    Variable numRows = DimSize(MatrixName,0)
    Variable numColumns = DimSize(MatrixName,1)
    Redimension/N=(numRows,numColumns) $NewMatrixName
    Variable i,j,k
            k = (j*5)+90
            if (k>360)
                k = k-360
                k = k
            $NewMatrixName[i][j] = MatrixName[i](j*5) - MatrixName[i](k)
    Display;DelayUpdate
    AppendImage $NewMatrixName;DelayUpdate
    ModifyImage $NewMatrixName ctab= {-4.82601,0.74151,VioletOrangeYellow,1};DelayUpdate
Thanks in advance.
After this:
add this:
Wave newMatrix = $NewMatrixName  // Create wave reference for new wave
Then use newMatrix instead of $NewMatrixName thereafter.
For details, execute:
It would also be a good idea to read the entire Programming help file or the equivalent first three chapters in the PDF manual
Hi hrodstein,
I have tried as you said but it is showing me following error.
Syntax Error: Got "NewMatrixName" instead of a string variable or string function name.
In your code, after the Duplicate operation and the statement creating the newMatrix wave reference, change all occurrences of $NewMatrixName to newMatrix.
Quote:
Hi hrodstein,
This is because ModifyImage takes an image name, not a wave reference. The reason for this subtle distinction is that you can append the same wave as an image to a given graph multiple times and each image must have a distinct name. This is analogous to the distinction between a trace name and a wave name. You can read about this by executing:
DisplayHelpTopic "Trace Names"
So the bottom line is that you need to pass an image name to ModifyImage, not a wave reference, like this:
Display;DelayUpdate
AppendImage NewMatrix;DelayUpdate
String ImageName = NewMatrixName
ModifyImage $ImageName ctab= {-4.82601,0.74151,VioletOrangeYellow,1};DelayUpdate
I created a separate ImageName local variable to make this subtle distinction more evident. You could also do this, which is equivalent:
One more thing - I removed all of the DelayUpdate calls. They do nothing in a user-defined function during which updates are off by default.
Here is the function with all of the changes:
    Wave MatrixName
    Display
    Wave NewMatrix = $NewMatrixName                 // Create wave reference for new wave
    Redimension/N=(numRows,numColumns) NewMatrix
    Variable i,j,k
            k = (j*5)+90
            if (k>360)
                k = k-360
                k = k
            NewMatrix[i][j] = MatrixName[i](j*5) - MatrixName[i](k)
    Display
Hi hrodstein,
Till now I am having the same problem... :(
I have attached the matrix by which I am trying...
matrix.zip (543.41 KB)
There was a similar issue in the first ModifyImage command, at the top of the function, where you were treating a wave reference name (MatrixName) as the name of an image. To understand the difference, execute:
Also
DisplayHelpTopic "Trace Names"   // Image names are analogous to trace names
I fixed this the same as I previously fixed the probem with the second ModifyImage command.
For clarity, I changed your "MatrixName" parameter to MatrixRef, to make it clear that it is a reference to a wave, not the name of a wave.
For the same reason, I changed NewMatrix to NewMatrixRef.
I also changed the NewMatrixName parameter to NewMatrixNameStr because it is not the name of a matrix but rather a string variable containing the name to use for the new matrix wave.
Here is the resulting function. I have marked the major changes with *** so you can see where they are.
Function PlotRelAnisotropyImage(MatrixRef, NewMatrixNameStr)
    Wave MatrixRef
    String NewMatrixNameStr
    Display
    AppendImage MatrixRef
    String ImageNameStr = NameOfWave(MatrixRef)                         // ***
    ModifyImage $ImageNameStr ctab= {-6.13085,0.465855,VioletOrangeYellow,1}    // ***
    Duplicate/O MatrixRef, $NewMatrixNameStr        // *** Added /O
    Wave NewMatrixRef = $NewMatrixNameStr                   // Create wave reference for new wave
    Variable numRows = DimSize(MatrixRef,0)
    Variable numColumns = DimSize(MatrixRef,1)
    Redimension/N=(numRows,numColumns) NewMatrixRef
    Variable i,j,k
            k = (j*5)+90
            if (k>360)
                k = k-360
                k = k
            NewMatrixRef[i][j] = MatrixRef[i](j*5) - MatrixRef[i](k)
    Display
    AppendImage NewMatrixRef
    String NewImageNameStr = NameOfWave(NewMatrixRef)
    ModifyImage $NewImageNameStr ctab= {-4.82601,0.74151,VioletOrangeYellow,1}
Finally, the Redimension call is unnecessary because, after Duplicate, the new matrix will have the same dimensions as the original matrix.
Hi hrodstein,
When I run the function, as an example:
PlotRelAnisotropyImage(matrix, test_matrix)
It is showing me the same error like:
Syntax Error: Got "test_matrix" instead of a string variable or string function name.
To speak the truth I don't understand why it is taking 'string function name'...???
Use:
PlotRelAnisotropyImage(matrix, "test_matrix")
The second parameter is a string and you passed a name (and the name was apparently not the name of a string variable).
doha420du wrote:
Hi hrodstein,
JimProuty wrote:
Use:
doha420du wrote:
Hi hrodstein,
Thanks...
