DrawAction problem
simcacl
I would like to cancel a line drawn in a Graph and substitute it with another line
Here part of the code I wrote:
here it draw the line:
SetDrawEnv gstart,gname= name
SetDrawEnv/W=$namegraph linefgc= (65280,0,0)
SetDrawEnv/W=$namegraph xcoord= bottom,ycoord= left
DrawLine/W=$namegraph 0,a1,a
SetDrawEnv gstop
here to cancel the line and substitute it (this is the part that does not work)
Drawaction/W=$namegraph getgroup=lineasoglia, delete, begininsert
DrawLine/W=$nomegraph 0,a,1,a
SetDrawEnv gstop
DrawAction endinsert
What is the problem?
Thanks
From the extract of code you posted it is hard to tell, so posting the entire experiment or procedure file is better.
You also should provide the version of Igor you are using.
Also, you don't say exactly what isn't working.
December 20, 2016 at 09:18 am - Permalink
I found the error just after posting the question
In the first drawing was missing the name of the window...
December 20, 2016 at 09:32 am - Permalink
