Covolution function fitting problem
ARES
I need to fit experimentally measured data to the convolution of an resolution function (gaussian) with an square function (for anglular resolution test).
I made a procedure with help of example. but it doesn't work well.
so please help me to edit procedure.
#pragma rtGlobals=3 // Use modern global access method and strict wave access. Function Convolres(pw, yw, xw) : FitFunc // linear DOS * Fermi, convolved with Gaussian energy resolution Wave pw, yw, xw // pw[0] = offset // pw[1] = energy resolution FWHM // pw[2] = square function initial position // pw[3] = square function finish position // pw[4] = square function amplitude // Make the resolution function wave W_res. Variable x0 = xw[0] Variable dx = (xw[inf]-xw[0])/(numpnts(xw)-1) // assumes even data spacing, which is necessary for the convolution anyway Make/FREE/D/N=(min(max(abs(3*pw[1]/dx), 5), numpnts(yw))) W_res // make the Gaussian resolution wave Redimension/N=(numpnts(W_res)+!mod(numpnts(W_res), 2)) W_res // force W_res to have odd length SetScale/P x, -dx*(numpnts(W_res)-1)/2, dx, W_res W_res = gauss( x, 0, pw[1]/(2*sqrt(2*ln(2))) ) +pw[0] Variable a = sum(W_res) W_res /= a // To eliminate edge effects due to the convolution, add points to yw, make the spectrum, // do the convolution, and then delete the extra points. Redimension/N=(numpnts(yw)+2*numpnts(W_res)) xw, yw xw = (x0-numpnts(W_res)*dx) + p*dx // square function variable i yw=0+pw[0] for(i=pw[2];i<pw[3];i+=1) yw[i]=pw[4] endfor Convolve/A W_res, yw DeletePoints 0, numpnts(W_res), xw, yw DeletePoints numpnts(yw)-numpnts(W_res), numpnts(W_res), xw, yw End
Irene
- You should state more clearly what the function should do and what exactly is failing ("doesn't work well" is rather ambiguous).
- Please put your function in <igor> tags and also don't forget to post the full code including any helping functions (your current post seems cut off).
- Even better would be if you could provide a minimal experiment file together with an explanation what you want to do and at which step stuff fails.
- It also never hurts to state your Igor-Version.
Hope that brings us a step closer to the solution.
November 10, 2016 at 12:23 am - Permalink
November 10, 2016 at 10:58 am - Permalink
November 10, 2016 at 12:42 pm - Permalink
I will assume that yw has a constant scale for what follows.
Now I have some suggestions.
* I think you can use this or an equivalent to create the W_res wave
I am rather certain the gauss(...) function in Igor returns a normalized Gauss. So the steps to integrate and divide (normalize the curve) are unnecessary.
* I think you can use this to create the square function ...
* Your function has no return value. So, it will do nothing.
* Once you have the changes made, test your function. Dump the results in to a test wave ...
November 13, 2016 at 08:23 am - Permalink
An all-at-once fitting function doesn't use the return value; instead it alters the yw input wave.
November 17, 2016 at 05:10 pm - Permalink
Oh. Yes of course. Thanks!
November 18, 2016 at 06:54 am - Permalink
