Only two-color color table
maniraj
First time, I am in need of plotting a data which are x, y, and intensity in format. I plotted the Intensity values using "color as f(z)". Intensity values scale from -1 to +1. I used "RedWhiteBlue256" color table. This table have shown finite values around zero nearly white in color. I would like to set white color only for 0. Could you suggest how can I do it. Thanks in advance for your help and suggestion.
I am using Igor 6 version.
Best,
Maniraj
For example, if you're plotting a 1D graph, try this command (replace "wv" and "int" with your wave names):
ModifyGraph zColor(wv)={int,-0.001,0.001,RedWhiteBlue,0}
Or in a 2D image plot:
ModifyImage int ctab= {-0.001,0.001,RedWhiteBlue,0}
If you need something fancier, read up on color index waves and the color wave editor (Data-Packages-Color Wave Editor). Igor 7 makes this even easier.
October 27, 2016 at 08:37 am - Permalink
October 27, 2016 at 08:48 am - Permalink
