Restore default window position
ChrisZ
I'm using Igor 6.3.7.2 on Windows 7 and have rather unsual problem: I don't know how it happend in the first place, but a dialog window moved partly offscreen, so I cannot access the top-most options or drag it back to the screen.
In particular it is the window that opens from the "Modify Trace Appearence" dialog when you click "Set as f(z)...".
When the window is opened I cannot use the command line, so I cannot control it in this way. Is there a way to restore the default window positions?
Thank you for your help!
Best regards,
Chris
October 17, 2016 at 06:33 am - Permalink
October 17, 2016 at 08:55 am - Permalink
Best regards,
Chris
October 20, 2016 at 10:01 pm - Permalink
