Clone Window
RGerkin
Function CloneWindow([win,replace,with,freeze])
String win // Name of the window to clone.
String replace,with // Replace some string in the windows recreation macro with another string.
Variable freeze // Make a frozen clone (basically just a picture).
if(ParamIsDefault(replace) || ParamIsDefault(with))
replace=""; with=""
if(ParamIsDefault(win))
win=WinName(0,1)
String win_rec=WinRecreation(win,0)
Variable i
for(i=0;i<ItemsInList(replace);i+=1)
String one_replace=StringFromList(i,replace)
String one_with=StringFromList(i,with)
win_rec=ReplaceString(one_replace,win_rec,one_with)
if(freeze)
Struct rect coords
GetWinCoords(win,coords)
SavePICT /WIN=$win as "Clipboard"
String newName=UniqueName(win,6,0)
LoadPICT /O/Q "Clipboard",$newName
Display /N=$newName /W=(coords.left,coords.top,coords.right,coords.bottom)
DrawPICT /W=$newName 0,0,1,1,$newName
Execute /Q win_rec
replace=""; with=""
win=WinName(0,1)
Variable i
if(freeze)
Struct rect coords
Execute /Q win_rec
CloneWindow, but replace all the traces with copies and puts those copies in one data folder. Data is not shared between the original and the clone.
Function CloneWindow2([win,name,times])
String win
String name // The new name for the window and data folder.
Variable times // The number of clones to make. Clones beyond the first will have _2, _3, etc. appended to their names.
win=WinName(0,1)
if(ParamIsDefault(name))
name=UniqueName2(win,"6;11")
name=CleanupName(name,0)
times=ParamIsDefault(times) ? 1 : times
String curr_folder=GetDataFolder(1)
NewDataFolder /O/S root:$name
String traces=TraceNameList(win,";",3)
Variable i,j
for(i=0;i<ItemsInList(traces);i+=1)
String trace=StringFromList(i,traces)
Wave TraceWave=TraceNameToWaveRef(win,trace)
Wave /Z TraceXWave=XWaveRefFromTrace(win,trace)
Duplicate /o TraceWave $NameOfWave(TraceWave)
if(waveexists(TraceXWave))
Duplicate /o TraceXWave $NameOfWave(TraceXWave)
// Copy error bars if they exist. Won't work with subrange display syntax.
for(i=0;i<ItemsInList(win_rec,"\r");i+=1)
String line=StringFromList(i,win_rec,"\r")
if(StringMatch(line,"*ErrorBars*"))
String errorbar_names
sscanf line,"%*[^=]=(%[^)])",errorbar_names
for(j=0;j<2;j+=1)
String errorbar_path=StringFromList(j,errorbar_names,",")
sscanf errorbar_path,"%[^[])",errorbar_path
String errorbar_name=StringFromList(ItemsInList(errorbar_path,":")-1,errorbar_path,":")
Duplicate /o $("root"+errorbar_path) $errorbar_name
for(i=1;i<=times;i+=1)
Execute /Q win_rec
if(i==1)
DoWindow /C $name
DoWindow /C $(name+"_"+num2str(i))
ReplaceWave allInCDF
SetDataFolder $curr_folder
String win
win=WinName(0,1)
Variable i,j
for(j=0;j<2;j+=1)
Execute /Q win_rec
if(i==1)
DoWindow /C $name
Duplicate /o $("root:"...
Any thoughts on this? Thanks!
February 3, 2012 at 08:50 am - Permalink
October 13, 2016 at 11:41 am - Permalink
CloneWindow2 code is now failing for me. This line:
does not work on a graph I have where the line is: "ErrorBars/T=0/L=0 r_TCP_710C_2min_0006_C Y,wave=(:WAXS:TCP_710C_2min_0006_C:s_TCP_710C_2min_0006_C,:WAXS:TCP_710C_2min_0006_C:s_TCP_710C_2min_0006_C)". errorbar_names is empty string after that line.
This is Igor 8.04. I think the problem are my parameters to Errorbars : /T=0/L=0. Can the syntax be changed to look for the content after the last "=" sign and skip the previous ones, if any are present?
May 8, 2020 at 09:59 am - Permalink
I think I fixed it, not sure if this will work always, but here is small code change which seems to work for me now:
SplitString/E=",.*" line
sscanf S_value,"%*[^=]=(%[^)])",errorbar_names
for(j=0;j<2;j+=1)
Note, I added SplitString which splits the "line" at first "," to remove ErrorBars with flags (which may contain additional "=").
Also, I needed to remove the ":" from "root" in the Duplicate command.
May 8, 2020 at 11:29 am - Permalink
