specific importing problem, rows to columns
remolorio
I got stuck with importing data output as attached to this post. I would like to import data from the following blocks:
Parameter Statistics
Peak 1 Voigt Area
Parm Value Std Error t-value 95% Confidence Limits
Area 1 2 3 4 5
Ctr 6 7 8 9 10
Wid 11 12 13 14 15
Shpe 16 17 18 19 20
Peak 2 Voigt Area
Area 21 22 23 24 25
Ctr 26 27 28 29 30
Wid 31 32 33 34 35
Shpe 36 37 38 39 40
etc. ...
into the following 3 waves:
filename_Peak filename_ctr file_name_Std_err
1 6 7
2 26 27
the complication is that the number of peaks varies
Sorry for posting such a general problem, I am igor beginner
Edit: please take the above example as a generic one, the attached file contains realistic numbers.
October 5, 2016 at 10:37 am - Permalink
October 5, 2016 at 02:07 pm - Permalink
I'd like to know what software generates this file format for future reference.
October 6, 2016 at 10:53 am - Permalink
Now I don't know if this is asked for too much since you already helped a lot but would it be possible to add a 4th and a 5th column containing the values of the "Amplitude" and "FWHM" columns of the block "Measured Values" (second block of the file). They don't come with statistical information though.
Concerning naming of the output wave at the end, I changed
Wave remoOutputData = CreateOutputDataWave("outputData", remoRawData)
to
Wave remoOutputData = CreateOutputDataWave(S_fileName, remoRawData)
..which would give me "30.txt" as a result. Is there a way to have the .txt extension removed?
These data files come from the program PeakFIT, commonly used in analysis of Raman spectra.
October 7, 2016 at 02:08 am - Permalink
