"Depth cue" setting in gizmo
![](/sites/default/files/styles/thumbnail/public/sjr51/profile-images/2018-07/cube.png?itok=iXDZATA2)
sjr51
Is this possible in a Gizmo windows using attributes? I've tried a bunch of things but I am kind of stuck. Previously I have coloured the points or paths according to z-depth, e.g. from black through to white. This looks good but only works for viewing along one axis. I'm using IP7.
September 27, 2016 at 10:46 am - Permalink
September 27, 2016 at 11:43 pm - Permalink
Additional: Attached is Gizmo graphic of Scatter and Path plots, after rotating the underlying x,y,z data -30 degrees around the 'Y' axis. The initial Z-scale coloring is maintained; an added light is used to accentuate the features, and is optional.
September 28, 2016 at 10:20 am - Permalink
September 28, 2016 at 12:42 pm - Permalink
Fog was possible in IP6 Gizmo under userLevel=9. I was not aware of a single user who asked for or used fog in the last 15 years but this example application certainly makes it worth exploring for a future version. I'm on vacation today so I have limited access or time to change anything but I'll look for a way to give you access to fog.
October 7, 2016 at 01:56 am - Permalink
October 7, 2016 at 04:23 am - Permalink
There may be various pragmatic approaches to obtaining the desired effect. In this instance you are displaying an extended object that would require a color wave for specification. Adding a "fog" to a color wave can be simple/constant or you can use something along the lines of: http://www.terathon.com/lengyel/Lengyel-UnifiedFog.pdf
October 18, 2016 at 02:18 pm - Permalink
