Exported Graphic Looks Different depending on DPI setting
mschulze
Although I have used Igor for many years on several computers, and I have never had this issue previously in creating publication quality images even when a journal requires a dpi setting of 600. Does anyone know if it's a screen resolution setting issue (such as a Windows 10 issue) or if there are steps I can take within Igor?
Thanks so much for your help.
Create the graphic, put in on a layout, and export the layout.
September 18, 2016 at 07:53 am - Permalink
See http://www.igorexchange.com/node/6460
This is possible via the "Computed Manual Ticks" option and "Set to auto values" button in the modify axis dialogue.
In IP6 this was not working by code (http://www.igorexchange.com/node/6908)
HJ
September 19, 2016 at 01:51 am - Permalink
I have seen people specify an annotation anchor location in, say, the right-bottom corner but then position the annotation in the upper margin. So, check if the anchor locations makes sense.
Also, please specify what version of Igor you are using.
Larry Hutchinson
WaveMetrics
support@WaveMetrics.com
September 19, 2016 at 12:50 pm - Permalink
My solution was simply 'use fixed settings'.
I tracked it and the last occurrence I could find was 6.38B01 (I don't have newer versions installed atm; not much to do and saving to buy IP7)
HJ
September 19, 2016 at 03:49 pm - Permalink
