    Findlevels Algorithm
I use the function "Findlevels" to treat my signals and it works very well. I wondered if it was possible to have the algorithm of this function because I want to reproduce exactly my program (procedure) in another programming language, C # for example. Is it possible ?
Many thanks,
August 31, 2016 at 07:50 am - Permalink
August 31, 2016 at 07:56 am - Permalink
I would like to have the same code and keep the same parameters used in the function Find Levels such as "Box" and "Level".
I could not find a simple way to do it :(
September 2, 2016 at 05:57 am - Permalink
As to your ending question ... I suggest you should contact WaveMetrics directly. I imagine that releasing code or even commenting that they might release it is not something they will do on a public forum. Finally, I might suggest that at best, you will get references to literature and still have to develop your own code. In other words, I seriously doubt that you will be handed a "code package" that you can just duplicate and use directly.
Which brings me back to my starting question.
September 3, 2016 at 07:34 am - Permalink
[quote=jjweimer]I would ask first ... Why go outside of Igor Pro when it already does exactly what you need?[/quote]
@jjweimer : We use Igor Pro for R&D. The goal was to test the algorithm on a large set of data then to make it an embedded software.
Since my last post here I have no longer worked on the issue. But, today I suddenly had a flash ;-).
Here is my solution
Here is an example (attached image) with the same parameters on a noisy data:
LookForIndex(myData,1, B=151)
FindLevels/B=151/Q/P/D=levelWave myData,1
December 2, 2016 at 08:18 am - Permalink
