I am a basic user of IgorPro using the dialogue boxes pretty much exclusively. I am trying to produce a simple scatter plot. The Y axis merely has 5 values representing risk levels. The X axis has time data measured in hours and minutes. The times may be negative numbers as an event may have begun prior to the reference time. I cannot seem to format the X-axis to display just hours and minutes with values beyond 24 - e.g. 44:30. Also I do not require a date. I have attached a screenshot of a test plot. Clearly there is something about time handling I am not understanding.
Any advice would be appreciated.Axes dailog box.jpg(88.39 KB)Test_Scatter_Plot.jpg(35.7 KB)
August 18, 2016 at 11:44 am - Permalink
Thank you for that. So simple when you know where to look !
August 23, 2016 at 06:04 am - Permalink
August 23, 2016 at 09:12 am - Permalink
