how to convert a graph of intensity vs wavenumber into a graph of intensity vs distance in labview
maximus
I used inverse fourier transform (in labview) to convert a graph of intensity vs wavenumber (with a constant distance between 2 adjacent wavenumbers) into a graph of intensity vs distance.
Do you know what s the the relationship between the wavenumber and distance when I use inverse fourier transform?
I need this relationship in order to calibrate the axis of distance after inverse fourier transform
* The units of a Fourier transform are the inverse of the original. The inverse is just going backward. So, Hz -> s with a Fourier transform, and s -> Hz with an inverse Fourier transform.
Otherwise, based on the practical undertones of your question, I might recommend that you start with your raw data and do this test ...
* Convert the raw data in Labview
* Convert the raw data in Igor Pro
* Compare the two Fourier transform results
You might be surprised to learn about the differences in what is returned by the two methods. Pay attention in particular to the two components of the return, the real part and the imaginary part. Also, pay attention to the magnitude of the return values. Finally, look at what you get for the separation between points (the "step size") in the two cases.
Finally, based on the general direction of your questions, I suggest that you might want to research a good book or book chapter on Fourier transforms and their applications.
June 30, 2016 at 07:27 am - Permalink
edit:
Maximus,
I just noticed that you referred to transforming an ITENSITY distribution. You should understand and appreciate the differences between coherent and incoherent imaging (or propagation) before blindly using my help file, which specifically assumed coherent propagation (and complex fields). The far-field intensity will be the magnitude squared of my FFT output, but you will have to make assumptions about the phase of your source intensity field. The lateral scaling will be common to both situations.
June 30, 2016 at 09:30 am - Permalink
