Trying to Load and Save 16-bit x3 color (RGB) TIFF Images ... Unsuccessfully?
astrostu
1) I can't seem to save 48-bit TIFF images. 16-bit just saves a 16-bit greyscale of an NxMx3 wave instead of color. Putting in /DS=48 reverts to a default (?) 8-bit greyscale. Command attempt (or /DS=48):
ImageSave /DS=16 /Q=1 /T="tiff" MasterImage as (s_image_path+s_image_folder+"Master.tiff")
2) I can't seem to properly load correctly saved (from Photoshop) 48-bit TIFF images. They load as 3-color, but revert to 8-bit (pixel values between 0 and 255), and they look like a pointillism-ist's dream.
I'm sure there has to be a way to do this, but I can't figure it out! If it matters, I'm using the latest v7 beta, but I had this issue in v6, too (with the /D flag instead of /DS for saving).
June 27, 2016 at 03:44 am - Permalink
June 27, 2016 at 08:50 am - Permalink
Testing in IP7:
I created a 48-bit image using:
Saved it into a 48-bit image:
and loaded it back using:
In IGOR 6.x if your 48-bit TIFF file is written with samplesPerPixel=3 it would be read by IGOR into a 3-layer RGB wave of type unsigned short. Since I do not have your image, I can only suggest that you run your load command with /RAT and then take a look at the tags.
If you see different results or to report anything else relating to IP7 please contact support@wavemetrics.com.
June 27, 2016 at 09:48 am - Permalink
b) The issue was /bigt=0. Setting that, and it loads perfectly fine. So it's Igor's library that works, the generic one that doesn't.
c) No idea why the saving now works. I wonder if it's because of the exact wave type before, that it needs to be unsigned 16-byte specifically?
d) A sample image was in my previous reply, but now that this works ... it works.
June 27, 2016 at 10:07 am - Permalink
I have no idea why IP6 did not work for you. When you encounter such difficulty you should contact support with the file in question.
June 27, 2016 at 11:59 am - Permalink
