Generating a uniform random distribution of points in a circle
sjr51
//// @param num number of points to be generated
Function UniformCircle(num)
Variable num
Make/O/N=(num) xw,yw
Variable tt,uu,rr
Variable i
for(i = 0; i < num; i += 1)
tt = 2 * pi * (0.5 + enoise(0.5))
uu = (0.5 + enoise(0.5)) + (0.5 + enoise(0.5))
if(uu > 1)
rr = 2 - uu
rr = uu
xw[i] = rr * cos(tt)
yw[i] = rr * sin(tt)
DoWindow/K resultPlot
Display/N=resultPlot yw vs xw
ModifyGraph/W=resultPlot mode=3,marker=8
ModifyGraph/W=resultPlot width={Plan,1,bottom,left}
Variable num
Variable tt,uu,rr
Variable i
if(uu > 1)
rr = 2 - uu
rr = uu
May 31, 2016 at 03:34 am - Permalink
Variable num
make/o/n=(num) r1,r2
Variable i,uu
for(i=0;i<num;i+=1)
r1[i]=0.5+enoise(0.5)
if(uu > 1)
r2[i] = 2 - uu
r2[i] = uu
Run the this code with e.g., 1e6 samples and execute the following commands:
duplicate/o M_wavestats rs1
wavestats/w r2
duplicate/o M_wavestats rs2
Edit/K=0 root:rs1.ld,root:rs2.ld
Now compare the avg, sdev, rms, adev and skew between the two...
The OP did not state explicitly what is meant by "uniform". My own guess would be: density that is independent of location inside the circle. One can verify angular uniformity using StatsCircularMoments with the /KUPR, but clearly if the radial distribution was also strictly uniform then the density of points per unit area would be higher closer to the origin. A joint histogram for xw and yw can help display the results:
NewImage M_JointHistogram
May 31, 2016 at 08:27 am - Permalink
