Does findlevels function treat input wave always as 1d wave regardless the original dimension?
I tried findlevels on a 2d wave and it shows the result in a 1d wave, and I can't reference columns in the command as wavename[][0].
Here is another approach for 2D waves. Create a single contour on a 2D image at your desired level. Add to your Procedure: #include<Extract Contours As Waves>
This will enable convenient extraction of a pair of 'x' and 'y' waves from the contour, whose (x,y) positions correspond to your level.
May 12, 2016 at 12:50 pm - Permalink
#include <Extract Contours As Waves>
May 14, 2016 at 08:40 am - Permalink
