Fitting surface to set of scatter points
scope
How do I fit a surface (that I know the mathematical model of) to a set of data points? Specifically, I have a 10,000 x 3 wave of x,y,z coordinates and I want to fit an elliptical cone of form x^2/a^2+y^2/b^2 = z^2/c^2? After that, I'd like to take the equation of the cross-sectional ellipse out based on a given height (z value). I'm currently trying to use Gizmo but I'm having trouble with it.
f(x,y) = x^2/a^2 + y^2/b^2
and then fit data where the Z values are transformed as z' = z^2. But something tells me we're not lucky...
That would mean that you are trying to fit an implicit equation. If you re-write it as
0 = x^2/a^2 + y^2/b^2 - z^2/c^2
then you can write a fit function with the RHS and use implicit fitting. To read more about implicit fitting, copy this command:
DisplayHelpTopic "Fitting Implicit Functions"
paste it into Igor's command line and press Enter. I think your fitting problem may not be easy- in particular, you won't actually be able to fit for a, b, and c. To see why, multiply my equation by c^2:
0 = x^2*c^2/a^2 + y^2*c^2/b^2 - z^2
Now it's easy to see that you have only two independent coefficients.
May 5, 2016 at 04:42 pm - Permalink
