Do Something while key is pressed AND held down
hegedus
Here is the problem I am trying to solve.
I want to present a folders worth of images (~1000-6000) to a user basically as fast as possible and when they see a change in the image stop and flag the change and then proceed.
Today I am using a window hook to present the next image, but that requires a key press and release to work. For example I use the return key to load the next image. If I hold the return down, only the single next image is loaded and then it waits for me to release the key.
Is it possible (or a better phrase how is possible) to keep loading images while a key is pressed and then stop when released?
* capture the keystroke on the down
- do the actions to advance the frame (and DoUpdate to refresh all windows)
- (pause 3 seconds for user review)
- return a code 0 to allow the hook to remain active
* capture the keystroke on the up
- return a code 1 to shut off the hook function
April 29, 2016 at 09:05 am - Permalink
April 29, 2016 at 09:32 am - Permalink
Unfortunately, Jeff is not right about "capturing the key release" because Igor doesn't send you separate key press and key release events. However, your hook function will be called repeatedly if you press and hold until the key repeat starts. But you have to return from the hook so that it can be called again.
And, yes, you probably want to return non-zero from the hook function to make sure Igor doesn't do anything with the keystrokes, like de-focussing the graph window and activating the command window. To avoid that problem, you could use an image subwindow in a panel, but better to return non-zero.
April 29, 2016 at 09:59 am - Permalink
http://www.igorexchange.com/project/ScrollTracesPanel
It allows for plug-in modules. All that would be needed is to have a module to advance the image. If nothing else, it would show you how I handeled keystroke events through the panel input.
April 30, 2016 at 07:09 am - Permalink
