writing "\" in a batch file
J-E Petit
the following function writes lines for a batch file. The associated .exe is called by writing "\hysplit\exec\hyts_std", but it comes out as "\\hysplit\\exec\\hyts_std", and thus the program does not execute. How should it be written in the beginning to be saved in the proper way?
J-E
Function BatchFile(dt) variable dt String shortDateStr = Secs2Date(dt, -1) variable day, month, year, dayOfWeek sscanf shortDateStr, "%d/%d/%d (%d)", day, month, year, dayOfWeek Variable time = mod(dt, 24*60*60) variable hour=trunc(time/(60*60)) string year_str=num2str(year)[2,3] string month_str=num2str(month) if (strlen(month_str)==1) month_str="0"+month_str endif string day_str=num2str(day) if (strlen(day_str)==1) day_str="0"+day_str endif string hour_str=num2str(hour) if (strlen(hour_str)==1) hour_str="0"+hour_str endif NVAR/Z trajduration=root:trajduration SVAR/Z PathToMetzFile=root:PathToMetFile SVAR/Z Trajprefix=trajprefix SVAR/Z Pathtotrajfolder=root:pathtotrajfolder string Batch_str Batch_str="echo "+year_str+" "+month_str+" "+day_str+" "+hour_str+" >CONTROL;" Batch_str+="echo 1 >>CONTROL;" Batch_str+="echo 49.11 6.23 50 >>CONTROL;" Batch_str+="echo "+num2str(trajduration)+" >>CONTROL;" Batch_str+="echo 0 >>CONTROL;" Batch_str+="echo 10000 >>CONTROL;" string gdasfile_list=OtherGDASFile(dt,trajduration) variable NbMetFile=itemsinlist(gdasfile_list) Batch_str+="echo "+num2str(NbMetFile)+" >>CONTROL;" variable i for (i=0;i<NbMetFile;i+=1) Batch_str+="echo "+PathToMetzFile+" >>CONTROL;" Batch_str+="echo "+stringfromlist(i,gdasfile_list)+" >>CONTROL;" endfor Batch_str+="echo "+pathtotrajfolder+" >>CONTROL;" Batch_str+="echo "+trajprefix+year_str+month_str+day_str+hour_str+ " >>CONTROL;" Batch_str+=";" Batch_str+="\hysplit4\exec\hyts_std;" print Batch_str Make/T/O/N=(ItemsInList(batch_str, ";")) batch_txt batch_txt = StringFromList(p, batch_str, ";") Newpath/O BatchPath, "C:hysplit4:working:" Save/T/G/O/M="\r\n"/P=BatchPath Batch_txt as "batch_run.bat" End Function
I'm not sure where you are seeing double-backslashes. Possibly you are seeing it in a literal string in the Igor debugger. In that case, a double-backslash means that there is one backslash character in the string. The debugger is simply displaying it as you would need to enter it in a command.
April 15, 2016 at 07:08 am - Permalink
"\\hysplit4\\exec\\hyts_std;"
, then in the batch it is written "\\hysplit4\\exec\\hyts_std".Anyway, strangely, using "/hysplit4/exec/hyts_std" works.... so I'll go for that
the other problem that I'm facing is to execute the batch file:
while executing
executeScriptText/B/Z "C:hysplit4:working:batch_run.bat"
doesn't do anything,executeScriptText/B/Z "C:\hysplit4\working\batch_run.bat"
launches the batch file, but leads to incomplete calculation. (just to mention that double clicking on the batch file works properly :) )April 15, 2016 at 07:20 am - Permalink
