Fitting for Complex Exponential Signal
bangkury
I am trying to fit my experimental data to complex exponential signal. I tried to use:
Curve Fitting -> Function -> exp
However, it seems like igor fitting function assumes only real coefficient since I could not get any meaningful fitting. Is there a way to fit complex exponential function?
I am also attaching igor file that contains data.
Thank you for your time
Wave w
Variable xx
//CurveFitDialog/ Equation:
//CurveFitDialog/ f(xx) = C * real(exp(cmplx(ar, ai)*xx))
//CurveFitDialog/ xx
//CurveFitDialog/ Coefficients 3
//CurveFitDialog/ w[0] = C
//CurveFitDialog/ w[1] = ai
//CurveFitDialog/ w[2] = ar
return w[0] * real(exp(cmplx(w[2], w[1])*xx))
I was unable to find a good ai to match the frequency of your signal, and the fit isn't really great. But at least it's doing something... :)
April 6, 2016 at 11:13 am - Permalink
