Function fit error
elle
I am trying to fit my data with the cone shape model. When I fit the data with that model, there was an error stated that "the fitting function returned NaN for at least one X value". I have tried to fix the error but didn't get anywhere. Can someone help me with this problem? I also attached the file containing the cone shape model. Thank you.
Cheers,
Elle
You can fix this by adopting files and reposting. For details, execute:
February 25, 2016 at 07:11 pm - Permalink
Thanks for the respond. I have attached a new file with the missing file in it. I hope it works this time. Thanks
February 25, 2016 at 09:47 pm - Permalink
Commenting out each occurrence of that line, I can open the experiment.
Now you need to tell us precisely what to do to cause the error. A command to execute would be ideal.
February 26, 2016 at 08:33 am - Permalink
I have no idea why there is an error to load the experiment file. Anyway, the problem that I am facing is, every time when I try to fit the data with the cone function that I wrote, there will be an error saying that :
What should I do to get rid of this error? I have tried to solve it but I am still getting that error. I had a felling that this is not a big issue but still, I don't know why I can't solve it. I hope you can help or lead me to solve this error. Thank you very much.
By the way, I attached the experiment's file once again. Finger crossed it will work this time.
Cheers,
Elle
February 28, 2016 at 02:11 pm - Permalink
February 28, 2016 at 05:32 pm - Permalink
