Importing Wave
kachy_89P
I created a funazione "highpass" to apply a filter to my data.
I created a simple GUI, but I can not load and set the best parameters.
I wish every time I load a wave, this has an automatic renaming, and that this name be scelato for example chosen by the operator, as in the box that I created. so every time you load a new wave, the first will have to remain still in memory and plotted, without being overwritten.
This is my procedure:
#pragma rtGlobals=3 // Use modern global access method and strict wave access. Menu "Vibration Filter" "FTT", VRB(); VF() EndMacro Function VRB() variable/G win string/G waveoutname string/g wm wave wavein = wm end Window VF() : Panel PauseUpdate; Silent 1 // building window... NewPanel /W=(10,60,260,540) SetVariable setvar_hf title="win", pos={23,112}, size={133, 20}, value=win; DelayUpdate SetVariable setvar_hf limits={-inf,inf,0} SetDrawEnv fsize= 12; DelayUpdate SetDrawEnv fname="Calibri" SetVariable setvar_waven title="wave in", pos={23, 88}, size={130, 20}, value=wm; DelayUpdate SetDrawEnv fname= "Calibri" SetDrawEnv fsize= 10;DelayUpdate Button button_HFF, pos={64,212}, size={99,41}, proc=VFB, title="High PSS" SetDrawEnv fname= "Calibri" Button button_HFF, fSize=14, fStyle=1 SetVariable setvar_WOUT title="waveout name",pos={10, 140},size={174,16}, value=waveoutname; DelayUpdate SetDrawEnv fname= "Calibri" Button button_loadwave, pos={18,28}, size={88,28}, proc=ButtonLWin, title="LOAD Wavein" end Function VFB(ctrlName) : ButtonControl string ctrlName NVAR win SVAR waveoutname SVAR wm wave/z wavein highpass(wavein, win, waveoutname) end Function/WAVE highpass(wavein, win, waveoutname) wave wavein variable win String waveoutname make/O/N=(numpnts(wavein)-win+1) wavetmp, waveout, waveout2 wavetmp= wavein[win/2+p-1] waveout=sum(wavein, pnt2x(wavein, p), pnt2x(wavein, p+win-1))/win // moving average 1 Hz waveout2=wavetmp-waveout duplicate/O waveout2, $waveoutname Wave wOut=$waveoutname wOut=waveout2 end // LOAD WAVE Function loadewavein() loadwave/G/N/O/L={0,0,0,1,1} end Function ButtonLWin(ctrlName) : ButtonControl string ctrlName loadewavein() end
February 19, 2016 at 07:44 pm - Permalink
February 20, 2016 at 01:06 am - Permalink
If I understand your question... one method is to add a Set Variable control to the panel and use
ControlInfo
to get the value entered in the control. The output variable "S_value" will hold this. You will have to be careful in entering wave names or providing error checking to be sure the string will be a legal name.February 20, 2016 at 10:21 am - Permalink
commands? They're not doing anything, because there are no DrawText, etc commands that would be affected by them.
If you want to set the controls font and size use the Control dialogs to set them.
Also, this in this code:
The wave wavein = wm part isn't useful: once the function ends the wavein wave reference disappears (it is local to the function.)
If that is just an unfinished part of the code and you intend to use the wavein reference, it should probably be something more like
February 20, 2016 at 10:47 am - Permalink
Yes, in fact those lines come from another part of the code which I then deleted .
I took your advice inserting $ wm in that function , but whenever I try to avvire " highpass " from the window that I created me always comes out the same mistake :
"Whilw excuting Make, the following error occurred: the numeber of points in a wave must be between 0 and 2147 milion.
February 20, 2016 at 11:13 am - Permalink
February 22, 2016 at 09:21 am - Permalink
