About V_chisq user defined curved fitting
How do you specify the weighting wave mentioned below and how to derive a meaningful ChiSq value?
V_CHISQ: A measure of the goodness of fit. It has absolute meaning only if you've specified a weighting wave containing the reciprocal of the standard error for each data point.
There is no particular advice on how to determine your estimate of the standard error of your data points. Some people are able to come up with a meaningful estimate based on a priori arguments, some use a sliding window and compute a standard deviation for the data within the window.
February 10, 2016 at 09:46 am - Permalink
February 10, 2016 at 11:55 am - Permalink
February 10, 2016 at 05:06 pm - Permalink
