function help
xueshao
i am a newbie want to make a table automaticlly, like one step movement.
it works in two columns,but fails in three columns. If somebody can give me advise,that would be nice
This would be not very difficult,thanks anyway
the twopcolumn function as below:
variable i=0, j=0, k=0, l=0, m=0, n=0,o=0,p=0,q=0
variable d1n, d2n, d3n
Prompt xstart, "Start value X position:"
Prompt ystart, "Start value Y position:"
Prompt xend, "End value X position:"
Prompt yend, "End value Y position:"
Prompt xstep, "Step size of X direction:"
Prompt ystep, "Step size of Y dirction:"
DoPrompt "Enter position parameters (in m)", xstart, ystart, xend, yend, xstep, ystep
if (V_Flag)
return -1 // User canceled
d1n=abs((xend-xstart)/xstep)+1 //number for X dimension
d2n=abs((yend-ystart)/ystep)+1 //number for Y dimension
make/D/N=((d2n*d1n), 200)/O test=0
for(k=0; k<=d1n-1; k+=1)
i=k*d2n
j=(k+1)*d2n
test[i,j][10]=xstart+k*xstep //make column 10 for X
for(l=0; l<=d2n-1; l+=1)
test[i+l][11]=ystart+l*ystep //make column 11 for Y
***********************************************************************8
three column function as below:
Prompt zstart, "Start value Z position:"
Prompt zstep, "Step size of Z direction:"
Prompt zend, "End value Z position:"
make/D/N=((d2n*d1n*d3n), 200)/O test=0
d3n=abs((zend-zstart)/zstep)+1 //number for Z dimension
for(m=0; m<=d3n-1; m+=1)
n=m*d1n*d2n
o=(m+1)*d1n*d2n
test[n,o][12]=zstart+m*zstep //make column 12 for Z
i=k*d2n*m
j=(k+1)*d2n*(m+1)
test[(m+1)*i+l][11]=ystart+l*ystep //make column 11 for Y
The code below compiles and creates a wave with points and data values. I'm not sure if this is ultimately what you are looking for, but maybe it's a start.
February 5, 2008 at 06:01 am - Permalink
Thanks for your comment.But the problem is not the missing a DoPrompt statement part.
The problem is around for and endfor part. the relation between the addtional m part(d3n) doesnot work well with k and l parts
Do you have some comments about that?
Thanks
February 5, 2008 at 09:15 am - Permalink
I'm sorry, but I really don't understand what you are trying to do here.
If you could provide an explanation of what exactly you expect these functions to do, and then what they are doing, that would be helpful. As is, I don't know that the problem is in the first place.
February 5, 2008 at 12:15 pm - Permalink
I don't know whether your problem has been resolved, but I wonder a) why the 2 dimensional example should run - there are two fors and three endfors. At least there should be one more loop for the 3 dimensional problem than for the 2 dimensional one. I b) also wonder what you try to achieve. Am I right that you want to assign function values to pairs (xy) or triples (xyz) of coordinates? Wouldn't that be easier using 2 and 3 dimensional waves, ie rows & columns (& layers)?. I realized that you make 2 dimensional waves for both cases where the number of rows depends on the number of coordinates and the number of columns is fixed to 200. Is there a reason for doing so?
March 4, 2008 at 01:32 pm - Permalink
I fix this problem now. Basic mathematic knowledge. Thanks for comments
March 7, 2008 at 08:11 am - Permalink
