How to make do-while function work? Thanks
I'm a newer to learn the igor procedure. I made a procedure about how the celsius degree change to Fahrenheit degree. The result sholud be two column showing these two temperature. Can somebody help me to check my procedure where was wrong.
Thank you very much.
Best wishes
Function Change()
variable fahr, celsius
variable lower, upper, step
lower=0
upper=301
step=20
fahr=lower
do
fahr+=20
celsius=5*(fahr-32)/9
while(fahr print fahr, celsius
Your posted code is incomplete and therefore does not compile. And please wrap the code in igor tags.
As thomas_braun observed, your code is incomplete, and difficult to read as formatted. I have made a guess at your intention for this code. Also igor tags have be used to improve readability.
This function will create two waves (arrays) and display them in a table.
Function Change()
Variable Numpts, Index
lower=0
upper=301
step=20
Index = 0
Numpts = Round((upper - lower)/step) + 1
//create waves (arrays) to hold temperature data
// "/O" overwrites a wave if it already exists
make /O/N=(Numpts) wFahrenheit, wCelsius
fahr=lower
do
WFahrenheit[Index] = fahr
wCelsius[Index] = celsius
fahr+=step
Index += 1
while(Index < Numpts )
Edit wFahrenheit, wCelsius
The following function will print results directly to the history window, without the need for creating waves. Maybe this is what you had in mind.
Function Change2()
Variable Numpts
lower=0
upper=301
step=20
fahr=lower
printf "%10s %10s\r", "Fahrenheit", "Celsius"
do
//print fahr, celsius
printf "%10.2f %10.2f\r", fahr, celsius
fahr+=step
while(fahr < upper )
History window display:
Fahrenheit Celsius
0.00 -17.78
20.00 -6.67
40.00 4.44
60.00 15.56
80.00 26.67
100.00 37.78
120.00 48.89
140.00 60.00
160.00 71.11
180.00 82.22
200.00 93.33
220.00 104.44
240.00 115.56
260.00 126.67
280.00 137.78
300.00 148.89
Note, that you don't need a loop to accomplish this task. Have a look at:
function change3(lower, upper, step)
    variable nPoints = floor((upper-lower)/step) + 1
    Make/O/D/N=(nPoints) Fahrenheit, Celsius
    SetScale/P x, lower, step, "°F", Fahrenheit
    Fahrenheit = x
    Celsius = 5 * (Fahrenheit-32) / 9
Then execute:
change3(0, 300, 20)
