Getting error 10001 when I try to load netCDF data
Hi all,
I am trying to load a netCDF file with IGOR. In the past, I did that couple of time successfully. However, I am getting this error now.
Load_NetCDF error : Not a netCDF file
Error (10001), while loading "\\home$\Downloads\wind.nc"
I tried the same file with GrADS (graphics software) and it was loaded with no problems. So, the file is not damaged.
Any ideas?
Stavros
Short answer - if you will attach your NetCDF file and tell me the command you are using to load it, the OS you are running, and the Igor version you are running, I will look into it.
The longer answer is . . .
There are various versions of NetCDF files. I have pasted a discussion of this below.
If your file is a netcdf4 file, you can load it using Igor's HDF5 loader. For information on activating the HDF5 loader, execute:
DisplayHelpTopic "HDF5XOP"
Here is a summary of the pertinent facts gleaned from http://www.unidata.ucar.edu/software/netcdf/docs/faq.html:
The original netCDF format, which was the only format created between 1989 and 2004, is called the "classic format" or "netCDF-3". It can be loaded by the user-contributed nc_load XOP available via http://www.wavemetrics.com/users/tools.htm.
netCDF-4 was introduced in 2004. It is based on HDF5 and therefore can be loaded by Igor's HDF5 browser.
netCDF-3 "is still the default format for new netCDF files and the form in which most netCDF data is stored." This means that most netCDF files can be read by the nc_load XOP but not by Igor's HDF5 browser.
netCDF-3 files start with these four bytes: 'C', 'D', 'F', 0x01.
netCDF-3 "64-bit offset" files start with these four bytes: 'C', 'D', 'F', 0x02.
netCDF-4 files start with these four bytes: 0x89 (octal 211), 'H', 'D', 'F'.
netCDF-3 files can be converted to netCDF-4 using the nccopy utilty from netCDF version 4.1 and later. As far as I can tell the nccopy utility is not available in binary form - you have to download from http://www.unidata.ucar.edu/downloads/netcdf/index.jsp and compile the source code.
netCDF-4 files come in two flavors: classic model and enhanced model. Both are based on HDF5.
Hi and thanks for the reply,
I've attached the nc file. What I tried was Load_netCDF command and I got that error. I tried hdf5 loader as well but it didn't work.
wind.zip (5.4 MB)
Talking about hdf5 loader, I would also like to load hdf5 files (I tried to attach it but possibly I can't as it is 50 mb). It is a satellite dataset. It has data for different satellite channels (downloaded from EUMETSAT). I can load it successfully, but when I select eg. Channel 1, I can see in the datasets field the image file that I want, but I can't open it. If I try to Load it, I get this message: While executing HDF5LoadImage, the following error occured: The image dataset's SUBCLASS attribute is incorrect - expected IMAGE GRAYSCALE, IMAGE TRUECOLOR, IMAGE BITMAP or IMAGE INDEXED.
Do you have any piece of advice?
Please repost your HDF5 question in a new thread.
I examined your NetCDF file using GBLoadWave, like this:
GBLoadWave/T={72,72}/W=1
Edit wave0
From this, I can see that the first four bytes are 67, 68, 70, 2. This is 'C', 'D', 'F', 0x02 which means that it is a NetCDF 3 "64-bit offset file". The NetCDF XOP referenced from https://www.wavemetrics.com/users/tools.htm does not support the 64-bit offset format because it was compiled with a version of the NetCDF library that predates it.
I created an experimental version for another user using a newer library. It does support the 64-bit offset format. It is available only for Windows and only for Igor32 (32-bit version of Igor).
You can download the experimental version here: http://www.wavemetrics.net/Downloads/Customers/nc_load-Win32-2014-10-30…
Drag your nc_load.xop file out of the way, such as to the desktop, and then install the contents of that zip file in Igor Extensions.
Hi and thank you very much for your help.
I have windows 8.1 on my laptop (64-bit) and Igor (32-bit). However, it worked correctly.
I will use it tomorrow on my office's desktop and I leave a feedback.
Thanks again,
Stavros
