Hook function on graph marquee interaction
bs
If not is there another solution?
I would like to move (optional: resize, rotate, etc) a region of interest on an image and call
imagestats/G={rowMin, rowMax, colMin, colMax}
for every interaction.
DisplayHelpTopic "Marquee Menus"
November 19, 2015 at 10:52 am - Permalink
Bump!
I request a window hook function return variable:
26 "marqueeaction" a marquee has been added, removed, or moved in position
This will remove the need to set and track global variables. My specific need is to track the movement of a marquee and keep users from extending it beyond the bounds of an image window.
March 14, 2020 at 11:20 am - Permalink
How about using a pair of hair-style graph cursors?
March 16, 2020 at 05:10 pm - Permalink
The marquee is being drawn within an image to set an RoI. I'm not clear how cross hair cursors will be easier or even doable to achieve what I need?
In the meantime, I have a window hook function that, on a mouse-up event, does a cross-check to reset the marquee when it has been dragged outside the image bounding. It works. It would just seem more effective/cleaner to only have to grab the specific event code I need.
March 16, 2020 at 08:32 pm - Permalink
Cross-hair cursors are just normal graph cursors but instead of just the circle or square icon, they have lines that extend across the plot area. With a combination of two cursors (you can even use cursors beyond the standard A and B so that you won't use up the most-used cursors) you can enclose a box on the graph, just like using a marquee. Further, you can make them free cursors so that they don't stick to specific data points in your image.
I've attached a screen shot of an image with cross-hair cursors.
One advantage is that a window hook gets notified when they move.
One possible disadvantage is that you might need to write some tricky code to create a mode where they move together, though if they are both selected the arrow keys will do that. I think you might still need your cross-check code if the cursors are on a zoomed-in graph.
There are lots of things you can do to change the appearance/behavior of graph cursors.
March 17, 2020 at 03:53 pm - Permalink
Thanks. Those two words "tricky code" throw me off. Also, the Marquee draws more efficiently for my applications.
Here is the the code to check and reset.
Function Hf_imgTImageHook(iwH) // WindowHookFunction
STRUCT WMWinHookStruct &iwH
variable hookResult = 0
switch(iwH.eventCode)
case 5: // mouseup
if (f_HasMQ())
ResetMQCoordinates(force=1)
hookResult = 1
break
endswitch
return hookResult
// has marquee
Function f_HasMQ()
GetMarquee/W=$k_imgDisplay/Z
return (v_flag)
Here's what I might prefer.
case 26: // marquee altered, added, or removed
if (f_HasMQ())
case 5: // handle Marquee BEFORE mouse up
hookResult = 1
break
endswitch
return hookResult
// has marquee
Function f_HasMQ()
return (v_flag)
But, I guess this is akin to splitting hairs at some point since I need to handle the mouse up AFTER the marquee anyway. Oh well.
I will soon have to figure out how to reset the marquee positions with zoomed graph scales.
March 17, 2020 at 06:54 pm - Permalink
Well, there's tricky and there's tricky. If you don't need a move-together mode, then you don't need that tricky code. And it's not all that tricky- just respond to the cursor event with a computation that moves the other cursor in the pair.
I personally like the appearance of the hair cursors (you don't have to have the circle and square icons, either). I have used hair cursors myself for similar sorts of things. But to each his own.
March 18, 2020 at 09:27 am - Permalink
I do have cases where I want the entire box to move, not just move the one side or the other side. For example, I would like to set an exact square or circular region as the RoI.
I'll reconsider the idea to switch to cross-hairs (*). This could solve my other annoying problem -- I need to get the RoI location in image pixel coordinates not in window point coordinates.
(*) ---> Ha! You have a Demo for that! Thanks.
March 18, 2020 at 11:08 am - Permalink
