Index out of range
ndanos
I'm trying to do the following:
make/n=7000 baseline
make/n=9000 perturbation
make/n=9000 final
and I want to set final=perturbation+baseline such that the last 2000 points of final are the last 2000 points of perturbation. Can you please help me with the indexing?
Thanks so much,
Nicole
final[7000,8999] = perturbation
Remember that Igor indices are zero-based. Count starting at zero!
November 3, 2015 at 05:16 pm - Permalink
November 3, 2015 at 06:42 pm - Permalink
Or, if you prefer, we have 1010 fingers.
November 4, 2015 at 09:24 am - Permalink
make/o/N=70000 sos_ramp_wave=1
make/o/N=333 sos_ramp_wave_on
make/o/N=333 sos_ramp_wave_off
sos_ramp_wave[0,332]= sos_ramp_wave_on
sos_ramp_wave[333, 69999]= sos_ramp_wave_off
I get an error that "sos_ramp_wave_off index out of range". And what the code does is it adds sos_ramp_wave_on to the beginning of sos_ramp_wave, but then takes the last value of sos_ramp_wave_off and repeats it 333 times at the end of sos_ramp_wave.
November 5, 2015 at 09:27 am - Permalink
I feel inadequate with only 110 fingers :)
steve
November 5, 2015 at 07:34 am - Permalink
I'm curious what you expect to happen, since sos_ramp_wave_off has only 333 points in it, but you are trying to fill 70000-333 69667 points.
If you want the next 333 points to be filled from sos_ramp_wave_off, you could do this:
sos_ramp_wave[333,665] = sos_ramp_wave_off[p-333]
The range is 333 to 665 because the range indexing uses inclusive end points.
November 5, 2015 at 10:09 am - Permalink
Oops. And I'm supposed to be the professional!
November 5, 2015 at 10:10 am - Permalink
There was a typo in my code. The correct code that I'm actually using is:
sos_ramp_wave[69666, 69999]= sos_ramp_wave_off// tried with [p-333]
And I still get the index out of bounds error.
Even if I had the index wrong, why is only the last value of sos_ramp_wave_off being copied in sos_ramp_wave? And why does it work for sos_ramp_wave_on without the extra reference?
Thanks in advance.
November 5, 2015 at 11:15 am - Permalink
This should work:
sos_ramp_wave[<strong>69667</strong>, 69999]= sos_ramp_wave_off[<strong>p - 69667</strong>]
November 5, 2015 at 01:02 pm - Permalink
I still don't quite understand the indexing on the right handside, and why it should be different for the on vs off wave.
November 5, 2015 at 01:43 pm - Permalink
sos_ramp_wave[69667, 69999]= sos_ramp_wave_off[p - 69667]
p runs from 69667 to 69999. But the row numbers in sos_ramp_wave_off are in the range [0,332], so you have to subtract 69667 to get row numbers appropriate to sos_ramp_wave_off.
Please read more than you ever wanted to know about this:
November 6, 2015 at 05:10 pm - Permalink
