Help!!!
I have a loop procedure (Function loop_test()) to do the function of “perform_auto_analysis()”. When I run loop_test() in the command, there will appear a dialog box asking the pathway (see the attached picture). Then I input the numbers (such as 9 and 9), the procedure will get the results. But when the procedure dose the second loop run, there still appear the dialog box asking the pathway. I need the data from the function of "perform_auto_analysis()" when I use different input values (such as the value in Function loop_test()).Thus, my question is how to use the rename code to fix this or other methods. Thank you very much.
function loop_test() variable BC_n=27, Scat_n=700, lim_BC=28.1, lim_Scat=801 variable/g BC_MASS_CAL variable/g Scat_cal do Scat_n = 600 BC_MASS_CAL = BC_n do Scat_cal = Scat_n perform_auto_analysis() Scat_n += 25 while (Scat_n < lim_scat) BC_n += 0.5 while (BC_n < lim_BC) end function perform_auto_analysis() variable/g HUMID_INSTRUMENT,LOW_GAIN_SCATTER_CHANNEL variable startx,endx // do it all: // assumes user has set up the path already, and .sp2 converted to simple-name ibws // first get variables: variable tm,t2, file_process_number = 0 variable fnum prompt tm, "Starting file x#:" prompt t2, "Ending file x#:" doprompt "input file info:",tm,t2 startx = tm endx = t2 if (tm == 0 && t2 == 0) // then expect a list of file numbers hard coded here: make/n=(5) File_Number_List = {2,3,5,6,7} variable/g NonSequentialFiles = 1 startx = File_number_list[0] endx = File_Number_list[numpnts(file_number_list)-1] fnum = File_number_list[0] else variable/g NonSequentialFiles = 0 fnum = startx endif //now for each file: variable tmr,tmr2 tmr = startMStimer make/n=0 file_start_stop_times,USED_MIN_PS_SIGNAL do if(HUMID_INSTRUMENT ==1) IF(LOW_GAIN_SCATTER_CHANNEL) // YES: load_Hsp2_data_with_LGSCAT(fnum) else // NO: load_Hsp2_data(fnum) endif else if(LOW_GAIN_SCATTER_CHANNEL) // yes load_sp2_data_with_LGSCAT(fnum) else load_sp2_data(fnum) endif endif //PRINT "1" full_initialize_workspace() //PRINT "2" generate_results() // THIS IS WHERE MOST OF IT HAPPENS. //PRINT "POST GEN" Distill_results() //PRINT "POST DISTILL" // record breaks between file wavestats/q time_dat make/o/n=2 st = {v_min,v_max} concatenate/np {st}, file_start_stop_times make/o/n=1 st variable/G THIS_FILE_MIN_PS_SIGNAL st = THIS_FILE_MIN_PS_SIGNAL concatenate/np {st}, used_min_ps_signal killwaves st // clear old data: if(file_process_number == 0) make/o/n=1 hist_c2c_delay,hist_scat_width //histogram/b={0,.5,100} cross_to_center_delay_all,hist_c2c_delay wavestats/q hist_c2c_delay wavestats/q hist_scat_width doupdate else doupdate endif wavestats/q hist_c2c_delay wavestats/q hist_scat_width if(fnum<= endx && startx != endx) clear_old_dataset() endif tmr2 = stopmstimer(tmr) tmr = startmstimer print "Time for file #", num2str(fnum)," was", tmr2/1e6, " seconds" if (NonSequentialFiles == 0) // Not non-sequential: fnum+=1 file_process_number+=1 else if (file_process_number < numpnts(file_number_list)-1) file_process_number +=1 fnum = File_number_list[file_process_number] else fnum = inf endif endif while(fnum<=endx) fraction_bc_with_front_fit() duplicate file_start_stop_times file_num;file_num = floor((p)/2)+startx make/o/n=51 psl_diams,psl_sigs // psl signals for 620 counts off 220s. PSL_diams[0,9] = {0.0166667,0.0333333,0.05,0.0666667,0.0833333,0.1,0.116667,0.133333,0.15,0.166667} PSL_diams[10,19] = {0.183333,0.2,0.216667,0.233333,0.25,0.266667,0.283333,0.3,0.316667,0.333333} PSL_diams[20,29] = {0.35,0.366667,0.383333,0.4,0.416667,0.433333,0.45,0.466667,0.483333,0.5} psl_diams[30,39] = {0.516667,0.533333,0.55,0.566667,0.583333,0.6,0.616667,0.633333,0.65,0.666667} PSL_diams[40,50] ={0.683333,0.7,0.716667,0.733333,0.75,0.766667,0.783333,0.8,0.816667,0.833333,0.85} psl_sigs[0,9] = {0.000111487,0.00714235,0.0814905,0.458905,1.75552,5.25922,13.3105,29.7747,60.6046,114.486} psl_sigs[10,19] = {203.549,344.115,557.428,870.288,1315.5,1932.02,2764.64,3863.18,5281.16,7074.06} psl_sigs[20,29] ={9297.55,12006.4,15254.8,19099.2,23604.8,28856.1,34971.9,42122.3,50545.1,60552.9} psl_sigs[30,39] = {72518.8,86823.9,103753,123347,145261,168730,192719,216228,238614,259756} psl_sigs[40,50] = {280029,300160,321075,343796,369396,398971,433577,474050,520653,572596,627681} // now, rename "_all" waves rename_results() variable/g binning_time_step bin_scat_data(binning_time_step) wave bscatter_amplitudes,bscatter_count,scatbin_times wave bc_mass duplicate/o bc_mass bc_ved bc_ved = (bc_mass*6/pi/2/1000)^(1/3) variable/G KO =0 variable/g FIX_PS2SCAT_GAIN if(!FIX_PS2SCAT_GAIN) wave w_coef if(HUMID_INSTRUMENT) variable/g PS_to_Scat_GAIN_wet = round(w_coef[1]*100)/100 else variable/g PS_to_SCAT_GAIN = round(w_coef[1]*100)/100 endif endif variable/g SPLICE_CHECKED if(SPLICE_CHECKED) splice_detectors() // knit together all the scaled detector measures of scattering of total bc to give a wider range of bc_scatter else dont_splice_detectors() // scale only bc_psfit_amplitudes to bc_scatter endif generate_mie_outputs() variable/g binning_time_step bin_bc_data2(binning_time_step) makedistrib("bc_ved",50) variable/g K0 K0=0 duplicate/o scatter_amplitudes scatter_diams variable/g scat_cal wave scatter_amplitudes scatter_diams = interp(scatter_amplitudes*620/scat_cal,psl_sigs,psl_diams) makedistrib("scatter_diams",100) calc_frac_bcpsfit(30,5,8,bc_mass,bc_times,bc_scatter) duplicate bc_ved bc_optd wave bc_scatter bc_optd = interp(bc_scatter, bcs,diams_large_volume) makedistrib("bc_optd", 50) duplicate bc_ved bc_ved18 bc_ved18 = (bc_mass*6/pi/1.8/1000)^(1/3) makedistrib("bc_ved18", 50) Get_sensitivity_to_non_bc() if(HUMID_INSTRUMENT ==1) rename_Hresults() endif // splice_leos() // bc_leo_source() if(HUMID_INSTRUMENT ==1) wave bc_hscatter if(SPLICE_CHECKED) wave s_source else endif else wave bc_scatter if(SPLICE_CHECKED) wave s_source else endif endif // for PSLs etc make_scatter_amplitude_image(60,200) // for bc: make_bc_massdist_image(60) make_bc_scatter_image(120,300,3,6) // for PSLs etc // make_scatter_amplitude_image(60,200) end
About the problem: The input variables (startx or tm, endx or t2) don't get saved anywhere and only exist for the time the function perform_auto_analysis() actually runs. So the program has to ask for the numbers every time the function executes in your do-loop.
There are at least two solutions. One would be to save the values, e.g., as global variables, and then recall the values from within the function on consecutive runs. This is rather convoluted and I would not recommend this approach unless you want to preserve the functionality of perform_auto_analysis() as is. Another approach would be to move the prompt for variables part out into your main function (which then gets only called once at start) and then use your numbers as input variables, i.e., perform_auto_analysis(tm, t2).
October 20, 2015 at 06:43 pm - Permalink
