Axis Zero Line At Diff. Value
Is there a way to have a zero line, but at y = 1, for instance?
Use draw tools to draw a line using plot relative for the x coordinates and axis left for the y. Here is an example (with output from the draw dialog.)
make/o jack=sin(x/8);display jack
•ShowTools/A arrow
•SetDrawEnv ycoord= left;DelayUpdateDrawLine 0,0.5,1,0.5
Larry Hutchinson
WaveMetrics
support@WaveMetrics.com
I believe it's possible...I was making waves by duplicating the waves I was using, then just setting them to whatever value I wanted and plotting them with the other waves.
I think I'll post this on the Igor Wish List...It would be great to, in the Modify Axis window / Ticks & Grids be able to have an offset option for the zero line.
On second thought...is it possible just to move/duplicate this thread to there?
