A easy problem. Help!
I'm a beginner. Why this procedure appear an error named "Variable radius"?
Function ValueDemo(radius)
Variable radius
return pi*radius^2
When I copy your function and paste it into my Procedure window, it compiles just fine. I suspect there is a problem with code before what you show here. Can you post the rest of your code?
Hi Johon,
Because there is the same name in my procedure, so the error appeared.
Thanks a lot.
