Issues creating dependent waves
I'm having a bugger of a time figuring out why my dependencies are broken.
On a button press, I want to load the files, and then make a plot wave which is dependent on the data I've just read in. That way, I can use the plot wave to do other things with in other places.
I made a test function to try out my logic, but it works, and I can't see how it is functionally different to what is below.
function doit()
    NVAR index =root:index //the global variable I'm using in the dependency already exists
    make/O w ={{1,2,3,4,5},{10,20,30,40,50}} //I'm reading my data into a 2D wave
    make/O/N=(dimsize(w,0)) dw //I'm creating my dependent wave from the size of my source wave
    SetFormula dw , "w[p][index]" //I'm setting the dependency in the same manner
end // a successful implementation
Now for my real code:
function loadFilesButtonProc(ctrlName) : ButtonControl
    String ctrlName
    //parameters to help me load files, track sizes, and make the dependency. Already exist
    SVAR ext    =root:Packages:AI:LoadPanelFolder:extension
    SVAR pat    =root:Packages:AI:LoadPanelFolder:pattern
    NVAR endSeqno    =root:Packages:AI:LoadPanelFolder:endSeqno
    NVAR endCh       =root:Packages:AI:LoadPanelFolder:endCh
    NVAR seqnoChooser =root:Packages:AI:LoadPanelFolder:seqnoChooser
    //removes a plot so I can kill its wave
    RemoveImage /W=LoadPanel#LoadPanelGraphs#surfPlot /Z surf_y
    //creates surf_x, sur_y, and surf_e. 2814 rows, 29 columns (for the debug data)
    // surf_x,y,e may already exist before this line, but get killed in the function before being remade
    // uses "loadwave" to read the text data into igor
    loadwaves("","",extension=ext, pattern=pat)
    //gets the size for future updates
    endSeqno = dimsize(surf_y,1)-1
    endCh = dimsize(surf_y,0)-1
    //This is my issue: These dependencies are broken, but I can't figure out why.
    //   I've tried making simpler instances, but they work!
    //   I've tried putting some "DoUpdates" in there, but they don't seem to do anything
    make/O/N=(dimsize(surf_y,0)), plot_x, plot_y, plot_e
    SetFormula plot_x , "surf_x[p][seqnoChooser]"
    SetFormula plot_y , "surf_y[p][seqnoChooser]"
    SetFormula plot_e , "surf_e[p][seqnoChooser]"
    //now plot it
    SetActiveSubwindow LoadPanel#LoadPanelGraphs#surfPlot
    AppendImage surf_y
    Label left "Seqno"
    Label bottom "Channel number"
    ModifyGraph mirror=2
It's probably "seqnoChooser" in
which is a local alias. Try to replace it with the absolute variable name
SetFormula plot_x , "surf_x[p][root:Packages:AI:LoadPanelFolder:seqnoChooser]"
HJ
Ok, that worked.
I also used a local variable in my short example, but that one was in root, so maybe that was the difference.
Thanks
AND it had an identical name.
NVAR idx =root:index //the global variable I'm using in the dependency already exists
SetFormula dw , "w[p][idx]"
should not have worked (although the variable is in root).
SetFormula is working on a global scope. It is not aware that it has been called from a function.
HJ
