Is there a relatively simple way (such as a keyword) to reverse the color range for a color table displayed in a popup menu control? For example, to show the grays color table ranging from white to black instead of black to white in a popup menu control.
I have a panel with a popupmenu (*COLORTABLEPOP*) for selecting a color table. There is also a checkbox to permit the user to invert the color table when it is used in a plot. The color table is used to color markers on a plot according to their value.
I had hoped to be able to display the color table on the panel in the same "orientation" as it would appear in use. That is, the rainbow color table in the popupmenu should display running from a low of blue to a high of red if the Invert CTab checkbox were selected.
My guess as to your use was going to be exactly that. The only suggestion is that you could use a small embedded image to show the color table. Like this:
Function PopMenuProc(pa) : PopupMenuControl STRUCT WMPopupAction &pa
switch( pa.eventCode ) case2: // mouse up String ColorTableName = pa.popStr ControlInfo/W=Panel0 ReverseCheck Variable checked=V_value ModifyImage/W=Panel0#G0 dummyColors ctab={*,*,$ColorTableName,checked} break case -1: // control being killed break endswitch
return0 End
Function ReverseCheckProc(cba) : CheckBoxControl STRUCT WMCheckboxAction &cba
switch( cba.eventCode ) case2: // mouse up ControlInfo/W=Panel0 ColorTablePop String ColorTableName = S_value ModifyImage/W=Panel0#G0 dummyColors ctab={*,*,$ColorTableName,cba.checked} break case -1: // control being killed break endswitch
What is your use case here?
September 8, 2015 at 11:32 am - Permalink
September 8, 2015 at 12:20 pm - Permalink
case 2: // mouse up
break
break
endswitch
case 2: // mouse up
break
break
endswitch
Function MakeThePanel()
if (WinType("Panel0") != 7)
Make/N=(500,2)/O dummyColors = p
NewPanel /W=(144,50,456,250)
PopupMenu ColorTablePop,pos={16.00,23.00},size={256.00,23.00},proc=PopMenuProc,title="Color Table:"
PopupMenu ColorTablePop,mode=4,value= #"\"*COLORTABLEPOPNONAMES*\""
CheckBox ReverseCheck,pos={100.00,59.00},size={51.00,16.00},proc=ReverseCheckProc,title="Reverse"
CheckBox ReverseCheck,value= 0
DefineGuide UGH0={FT,91},UGH1={UGH0,19},UGV0={FL,78},UGV1={UGV0,173}
Display/W=(54,50,225,150)/FG=(UGV0,UGH0,UGV1,UGH1)/HOST=#
AppendImage dummyColors
ModifyImage dummyColors ctab= {*,*,BlueHot,0}
ModifyGraph margin(left)=-1,margin(bottom)=-1,margin(top)=-1,margin(right)=-1
ModifyGraph mirror=0
ModifyGraph noLabel=2
ModifyGraph axThick=0
RenameWindow #,G0
SetActiveSubwindow ##
DoWindow/F Panel0
Execute MakeThePanel() to try it out.
September 9, 2015 at 10:18 am - Permalink
Your example works very nicely. This will be a simple addition to my panel.
Maybe this capability will be present in a forthcoming major platform upgrade.
Thanks for the quick code example.
Jeff
September 9, 2015 at 12:01 pm - Permalink
I've incorporated your ideas into my panel.
Thanks.
Jeff
September 11, 2015 at 01:44 pm - Permalink
September 14, 2015 at 10:02 am - Permalink
