Button press required twice to update values
The plot updates on the first button push. The variables xrdYAxisMin and xrdYAxisMax don't update until I push the button again.
I want to track the values of the axes so I can do other things with them.
What am I doing wrong?
A minimised version of the code is:
//--------------------------------------------------------------------------- function updateCWTWindowProc(ctrlName) : ButtonControl String ctrlName NVAR xAxisMin =root:Packages:PeakPanelFolder:xAxisMin NVAR xAxisMax =root:Packages:PeakPanelFolder:xAxisMax NVAR xrdYAxisMin =root:Packages:PeakPanelFolder:xrdYAxisMin NVAR xrdYAxisMax =root:Packages:PeakPanelFolder:xrdYAxisMax //Data window SetActiveSubwindow PeakPanel#G1 SetAxis/A=2 //autoscales the Y axis to match the values in the current X range SetAxis bottom xAxisMin,xAxisMax GetAxis /Q left xrdYAxisMin = V_min xrdYAxisMax = V_max end //---------------------------------------------------------------------------
Full code for the button if I mangle the above:
//--------------------------------------------------------------------------- function updateCWTWindowProc(ctrlName) : ButtonControl String ctrlName Variable autoScaleInt=0 ControlInfo/W=PeakPanel peakAutoScaleIntCheck if(V_Value) autoScaleInt=1 endif NVAR cwtColour =root:Packages:PeakPanelFolder:cwtColour NVAR xAxisMin =root:Packages:PeakPanelFolder:xAxisMin NVAR xAxisMax =root:Packages:PeakPanelFolder:xAxisMax NVAR xrdYAxisMin =root:Packages:PeakPanelFolder:xrdYAxisMin NVAR xrdYAxisMax =root:Packages:PeakPanelFolder:xrdYAxisMax NVAR cwtYAxisMin =root:Packages:PeakPanelFolder:cwtYAxisMin NVAR cwtYAxisMax =root:Packages:PeakPanelFolder:cwtYAxisMax //CWT window SetActiveSubwindow PeakPanel#G0 ModifyImage M_CWT ctab= {-cwtColour,cwtColour,RedWhiteBlue,0} SetAxis bottom xAxisMin,xAxisMax SetAxis left cwtYAxisMin, cwtYAxisMax //Data window SetActiveSubwindow PeakPanel#G1 if(autoScaleInt) SetAxis/A=2 //autoscales the Y axis to match the values in the current X range SetAxis bottom xAxisMin,xAxisMax GetAxis left xrdYAxisMin = V_min xrdYAxisMax = V_max else //Need a way to preserve the values that I already have SetAxis /A //clears any previous autoscaling SetAxis left xrdYAxisMin, xrdYAxisMax SetAxis bottom xAxisMin,xAxisMax endif SetActiveSubwindow PeakPanel end //---------------------------------------------------------------------------
GetAxis
before the update happens (which is after the function ends). You need to force the graph (and with it the axis range) to update before fetching the new values withGetAxis
(or else you will get the old ones). Squeeze aDoUpdate
in before and you should be good to go. By the way, you don't useGetAxis/Q
not litter the history window?September 2, 2015 at 06:57 pm - Permalink
DoUpdate
works a charm.Yes it does litter, but I was trying to debug, so I wanted the rubbish.
/Q
is now inserted.September 2, 2015 at 08:45 pm - Permalink
