Multi-Experiment Process, ask if I want to save change to experiment "Untitled" all the time.
chrisNell
I have done a batch function based on the explanation to sequentially open experiment file find in: Choose File->Example Experiments->Programming->Multi-Experiment Process.
I manage to make a nice code using this example. Everything works well when I follow the tutorial but when I want to implement my own function I have a problem. It comes from a Hook function in my experiment:
static Function IgorStartOrNewHook(igorApplicationNameStr)
String igorApplicationNameStr
If I use this function, igor will ask before every new experiment:
Do you want to save change to experiment "Untitled"?
somebody have any idea why? Thanks again
Chris
Your function may be setting globals you don't expect (like V_Flag).
You can use the ExperimentModified operation to tell Igor you don't consider the current experiment in need of saving.
August 14, 2015 at 04:14 pm - Permalink
Hello Jim,
Thank you for your reply, I already try ExperimentModified without success but maybe I called it at the wrong point, so I will try other combinations. The whole function is bellow, it is the function taken from Igor: Choose File->Example Experiments->Programming->Multi-Experiment Process. The modification is only a simple callback. It mimics the real modification that I have in my code but it may be easier for you to understand this code provided directly by Igor developers.
#include "IgorTools"
// ABOUT MULTI-EXPERIMENT PROCESS
// This procedure file demonstrates a process that runs across multiple experiments.
// The challenge was to open a series of packed experiment files (with ".pxp" extensions) in a particular folder.
// Each experiment file contained waves named wave_lif1 and wave_lif2. We were asked to graph these waves
// and then export the graph as a PNG file and then to repeat the process for the next experiment.
// This file contains the procedures that cycle through experiments and execute a function for each experiment.
// When a file is opened, Igor calls the AfterFileOpenHook hook in this file. The hook checks to see if
// the file being opened is a packed experiment file and if it contains the expected waves. If so,
// the hook function calls a subroutine that graphs the waves and exports the graph as a PNG file.
// It then opens the next experiment file and repeats the process.
// This procedure file uses Igor's LoadPackagePreferences and SavePackagePreferences to store
// information used between invocations of AfterFileOpenHook. It uses Execute/P to post commands
// to Igor's operation queue for opening the next experiment.
// TO TRY THE DEMO
// Choose File->Example Experiments->Programming->Multi-Experiment Process to open
// the demo experiment and follow the instructions therein.
Menu "Macros"
"Start Multi-Experiment Process", /Q, StartMultiExperimentProcess()
// NOTE: If you use these procedures for your own purposes, change the package name
// to a distinctive name so that you don't clash with other people's preferences.
static StrConstant kPackageName = "Multi-experiment Process"
static StrConstant kPreferencesFileName = "ProcessPrefs.bin"
static Constant kPrefsRecordID = 0 // The recordID is a unique number identifying a record within the preference file.
// In this example we store only one record in the preference file.
// The structure stored in preferences to keep track of what experiment to load next.
// If you add, remove or change fields you must delete your old prefs file. See the help
// topic "Saving Package Preferences" for details.
Structure MultiExperimentProcessPrefs
uint32 version // Prefs version
uint32 processRunning // Truth that we are running the mult-experiment process
char folderPath[256] // Path to folder containing experiments
uint32 index // Zero-based index of next experiment in folder to load
uint32 experimentsProcessed
uint32 experimentsSkipped
EndStructure
// In version 101 of the prefs structure we increased folderPath from 100 to 256 bytes
static Constant kPrefsVersionNumber = 101
// Loads preferences into our structure.
static Function LoadPackagePrefs(prefs)
STRUCT MultiExperimentProcessPrefs &prefs
Variable currentPrefsVersion = kPrefsVersionNumber
// This loads preferences from disk if they exist on disk.
LoadPackagePreferences /MIS=1 kPackageName, kPreferencesFileName, kPrefsRecordID, prefs
// Printf "%d byte loaded\r", V_bytesRead
// If error or prefs not found or not valid, initialize them.
if (V_flag!=0 || V_bytesRead==0 || prefs.version!=currentPrefsVersion)
prefs.version = currentPrefsVersion
prefs.processRunning = 0
prefs.folderPath = ""
prefs.index = 0
prefs.experimentsProcessed = 0
prefs.experimentsSkipped = 0
SavePackagePrefs(prefs) // Create default prefs file.
// Saves our structure to preferences.
static Function SavePackagePrefs(prefs)
SavePackagePreferences kPackageName, kPreferencesFileName, kPrefsRecordID, prefs
// This is the routine that you would need to change to use this procedure file for your own purposes.
// See comments about labeled "TO USE FOR YOUR OWN PURPOSES".
static Function ProcessCurrentExperiment(prefs)
String folderPath = prefs.folderPath
String experimentName = IgorInfo(1)
String tmp = RemoveEnding(experimentName, ".pxp")
String fullFilePath = folderPath + tmp + ".png"
Display wave_lif1 wave_lif2
ModifyGraph rgb(wave_lif1)=(0,0,65280),rgb(wave_lif2)=(0,52224,0)
ModifyGraph mirror=2
// Add annotation
String text
sprintf text, "Experiment %d, \"%s\"", prefs.index, experimentName
TextBox/C/N=text0/M/H=36/A=LT/X=5.00/Y=0.00 text
SavePICT/E=-5/RES=600/I/W=(0,0,4,3)/O as fullFilePath
static Function IsAppropriateExperiment()
if (WaveExists(wave_lif1) && WaveExists(wave_lif2))
print "We have found an experiment"
return 1 // This looks like the kind of function we want to process.
print "Not appropriate experiment"
return 0 // This does not appear to be the kind of experiment we want to process.
// Returns full path to the next experiment file to be loaded or "" if we are finished.
static Function/S FindNextExperiment(prefs)
NewPath/O/Q MultiExperimentPath, folderPath
String nextExpName = IndexedFile(MultiExperimentPath, prefs.index, ".pxp")
if (strlen(nextExpName) == 0)
return ""
String fullPath = prefs.folderPath + nextExpName
return fullPath
// Posts commands to Igor's operation queue to close the current experiment and open the next one.
// Igor executes operation queue commands when it is idling - that is, when it is not running a
// function or operation.
static Function PostLoadNextExperiment(nextExperimentFullPath)
String nextExperimentFullPath
Execute/P "NEWEXPERIMENT " // Post command to close this experiment.
// Post command to open next experiment.
String cmd
sprintf cmd "Execute/P \"LOADFILE %s\"", nextExperimentFullPath
Execute cmd
static Function IgorStartOrNewHook(igorApplicationNameStr) //Christophe Nell: This is the new hook function that I need for my own experiment
print "IgorStartOrNewHook" //With a message or any other action, it always asks me 'Do you want to save "untitled" experiment?'
// This is the hook function that Igor calls whenever a file is opened. We use it to
// detect the opening of an experiment and to call our ProcessCurrentExperiment function.
static Function AfterFileOpenHook(refNum,file,pathName,type,creator,kind)
Variable refNum,kind
String file,pathName,type,creator
STRUCT MultiExperimentProcessPrefs prefs
LoadPackagePrefs(prefs) // Load our prefs into our structure
if (prefs.processRunning == 0)
return 0 // Process not yet started.
// Check file type
if (CmpStr(type,"IGsU") != 0)
return 0 // This is not a packed experiment file
// Check for expected waves
if (IsAppropriateExperiment())
prefs.index += 1 // Index tracks next experiment to be processed.
prefs.experimentsProcessed += 1
DoAlert 0, "This experiment is not suitable. Skipping to next experiment."
prefs.experimentsSkipped += 1
// See if there are more experiments to process.
String nextExperimentFullPath = FindNextExperiment(prefs)
if (strlen(nextExperimentFullPath) == 0)
// Process is finished
prefs.processRunning = 0 // Flag process is finished.
String message
sprintf message, "Multi-experiment process is finished. %d experiments processed, %d skipped.", prefs.experimentsProcessed, prefs.experimentsSkipped
DoAlert 0, message
// Load the next experiment in the designated folder, if any.
PostLoadNextExperiment(nextExperimentFullPath) // Post operation queue commands to load next experiment
return 0 // Tell Igor to handle file in default fashion.
static Function PossiblySaveCurrentExperiment()
DoIgorMenu/C "File", "Save Experiment" // Check if current experiment can be saved.
if (V_flag == 0) // Experiment is not modified.
DoAlert 2, "Save current experiment before starting?"
if (V_flag == 1) // Yes
SaveExperiment
if (V_flag == 3) // Cancel
return -1
// Allow user to choose the folder containing the experiment files and start the process.
Function StartMultiExperimentProcess()
print "StartMultiExperment"
// First save current experiment if necessary.
if (PossiblySaveCurrentExperiment())
return -1 // User cancelled
// Ask user to choose the folder containing experiment files to be processed.
String message = "Choose folder containing experiment files"
NewPath/O/Q/M=message MultiExperimentPath // Display dialog asking for folder
if (V_flag != 0)
return -1 // User canceled from New Path dialog
PathInfo MultiExperimentPath
LoadPackagePrefs(prefs) // This initializes prefs if they don't yet exist
prefs.processRunning = 1 // Flag process is started.
prefs.folderPath = S_path // S_path is set by PathInfo
prefs.index = 0
// Start the process off by loading the first experiment.
print "PostLoadNextExp"
PostLoadNextExperiment(nextExperimentFullPath) // Start the process off
August 17, 2015 at 12:51 am - Permalink
getfilefolderinfo/D
newpath/O cgms S_path
String dirList = IndexedDir(cgms, -1, 0), cmd
Variable numDirs = ItemsInList(dirList)
// Store directory list in a free text wave.
// The free wave is automatically killed when the function returns.
Make/N=(numDirs)/T/FREE dirs = StringFromList(p, dirList)
Variable i
for( i=0; i<numDirs; i+=1)
NewPath/O myPath S_path + dirs[i]
String ExperimentFile = IndexedFile(myPath,-1,".pxp")
if(cmpstr(ExperimentFile, "") == 1)
string directory = S_path + dirs[i] + ":" + StringFromList(0, ExperimentFile, ";")
sprintf cmd "Execute/P \"LOADFILE %s\"", directory
Execute cmd
Execute/P "CN_testExperiment()"
Function CN_testExperiment()
PathInfo/s home
String tmp = RemoveEnding(S_path, ".pxp")
String fullFilePath = tmp + ".png"
// Add annotation
String text
sprintf text, "Experiment \"%s\"", experimentName
and if I had the following hook function, the batch function ask me all the time if I want to save the untitled experiment:
Newdatafolder/o root:packages
Newdatafolder/o/s root:packages:PatchModeOli
Make/t/o/n=(4,3) GainDAC
Make/t/o/n=(4,3) GainADC0
Make/t/o/n=(4,3) GainADC1
August 18, 2015 at 01:02 am - Permalink
I have solved my problem by adding
"ExperimentModified 0"
at the end of the hook function that was responsible of my problem! Thanks a lot for your reply, best
Christophe
August 18, 2015 at 01:33 am - Permalink
<pre><code class="language-igor"></code></pre>
tags to your code posting so that we can read it. Without those tags, certain characters are interpreted as formatting instead of code. See http://www.igorexchange.com/node/25 for more info.John Weeks
August 18, 2015 at 09:20 am - Permalink
