Update a graph using a slider
igornoob12
I am trying to update a graph by choosing the initial and final indices of the data wave using sliders.
I have something like this:
Window graph() : Graph
Variable start,stop
PauseUpdate; Silent 1 // building window...
start = 0
stop = DimSize(pos,0)
display vel[start,stop] vs pos[start,stop]
ControlBar 42
Slider slider0 vert=0,proc=SliderProc,limits={0,DimSize(pos,0),0}
EndMacro
Function SliderProc(ctrlName,sliderValue,event) : SliderControl
String ctrlName
Variable sliderValue
Variable event // bit field: bit 0: value set, 1: mouse down, 2: mouse up, 3: mouse moved
if(event %& 0x1) // bit 0, value set
Variable start,stop
start = 0
ControlBar 42
EndMacro
String ctrlName
How do I proceed to make the graph update based on the values of start, stop?
Thanks
duplicate /O /R(Start,Stop) datawave root:displaywave
within your if clause.(Usually I have a fixed frame size and only use an assignment, but with dynamic ranges overwriting might be better than redefining)
Other opinions?
HJ
July 9, 2015 at 03:32 pm - Permalink
July 9, 2015 at 04:11 pm - Permalink
If not, you can look at that code to see how a slider can change a graph's axis range.
String name // name of this slider control
Variable value // value of slider
Variable event // bit field: bit 0: value set; 1: mouse down, // 2: mouse up, 3: mouse moved
String dfSav= GetDataFolder(1)
String grfName= WinName(0, 1)
SetDataFolder root:Packages:WMAxisSlider:$(grfName)
NVAR gLeftLim,gRightLim
SVAR gAxisName
GetAxis/Q $gAxisName
Variable dx= (V_max-V_min)/2
Variable x0= value*(gRightLim-gLeftLim)+gLeftLim
SetAxis $gAxisName,x0-dx,x0+dx
SetDataFolder dfSav
return 0 // other return values reserved
July 9, 2015 at 04:49 pm - Permalink
Unless I misunderstood your solution I don't want to change the axis range but the number of wave data points that are displayed.
July 10, 2015 at 10:56 am - Permalink
Thank you for the suggestion.
Here is what I got:
Variable/G start,stop
start = 0
display vel vs pos
ControlBar 42
Slider slider0 vert=0,proc=SliderProc,limits={0,DimSize(pos,0),0},size={300,63},ticks=0, variable=stop
Slider slider1 vert=0,proc=SliderProc,limits={0,DimSize(pos,0),0},size={300,63},ticks=0, variable=start
EndMacro
String ctrlName
wave pos,vel
NVAR start,stop
if (CmpStr(ctrlName,"slider0"))
stop = sliderValue
elseif (CmpStr(ctrlName, "slider1"))
start = sliderValue
ReplaceWave trace= vel, vel[start,stop];DelayUpdate
ReplaceWave/X trace= vel, pos[start,stop]
However, both sliders become coupled for some reason. i.e changing one also changes the other at the same time.
EDIT:
Nevermind, I figured it out. CmpStr returns "False" if the strings are equal.
July 10, 2015 at 11:53 am - Permalink
Technically, CmpStr returns 0 (not "false") if the strings are equal.
It also returns -1 if the first string is lexically "less than" the second, and it returns +1 if greater.
July 10, 2015 at 04:04 pm - Permalink
StringMatch
has the expected behavior in the above code. The matching criteria is a bit loose, as case sensitivity and such is not included. But by using wildcards one can also write case switches for groups of controls.July 13, 2015 at 12:20 am - Permalink
