Cook's distance
J-E Petit
Due to leverage effect, a "simple" linear regression (i.e. least square approach) between 2 variables may be influenced by outliers. They can be detected for example by the Cook's distance method (https://en.wikipedia.org/wiki/Cook%27s_distance)
Is there a built-in function to perform such a calculation? (if no, I may spend some time to write, and would surely bother you with more specific questions :) )
or is there a robust mode for linear regression already implemented?
J-E
Variable V_fitOptions=2
Be aware that we make no attempt to come up with correct error estimates in this case. Probably the only correct way to do it would be a Jackknife or Bootstrap approach.
It shouldn't be *too* hard to implement Cook's distance.
July 8, 2015 at 09:42 am - Permalink
