Loop matrix
Marta
I have written a procedure where the waves are sorted by time of day and then the statistics is calculated for each hour. There are several waves and I would like to do a loop in the Function CalcConcStats_BC_Test(sortedTimeOfDay, sortedBC1, sortedBC2, averagingIntervalInMinutes) to avoid writing code for each wave (I mean: BC1Stats, BC2Stats,...).
I have tried to do a wavelist, but it does not work.
Thanks in advance, I would really appreciate any help you could provide!
Please find attached a .txt file with some data (Prueba_Stats_BC.txt).
Here is the procedure:
#pragma rtGlobals=3 // Use modern global access method and strict wave access. //------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ //----------------------------------------------------------------------------------------- SELECT BC waves to be sorted ----------------------------------------------------------------------------------------- //------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ Function WavesSorted_BC_Test() String date_utc_time //Name of the Date&Time wave that we want to analyze string BC1 string BC2 prompt date_utc_time, "Date&Time wave to be sorted", popup WaveList("*", ";", "") prompt BC1, "BC1 wave to be sorted", popup WaveList("*", ";", "") prompt BC2, "BC2 wave to be sorted", popup WaveList("*", ";", "") DoPrompt "Waves sorted", date_utc_time, BC1, BC2 SortedByTimeOfDay_BC_Test($date_utc_time, $BC1, $BC2) End //-------------------------------------------------------------------------------------------------------------------------------------------------------------------------- //-------------------- Function to sort input Date&Time wave by the time of day. NaNs (blanks) go to the end -------------------- //-------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Function/S SortedByTimeOfDay_BC_Test(date_utc_time, BC1, BC2) wave date_utc_time //Date&Time wave to be sorted wave BC1, BC2 //BC waves to be sorted variable i duplicate/O date_utc_time, TimeOfDay_Sorted duplicate/O BC1, BC1_Sorted duplicate/O BC2, BC2_Sorted TimeOfDay_Sorted = mod(date_utc_time, 24*60*60) // TimeOfDay now contains just time of day (remove date) Sort {TimeOfDay_Sorted,date_utc_time}, TimeOfDay_Sorted, BC1_Sorted, BC2_Sorted // Sort by TimeOfDay, then by date CalcConcStats_BC_Test(TimeOfDay_Sorted, BC1_Sorted, BC2_Sorted, 60) End //---------------------------------------------------------------------------------------------------------------- //-------------------- Function to estimate the statistics of the waves -------------------- //---------------------------------------------------------------------------------------------------------------- Function CalcConcStats_BC_Test(sortedTimeOfDay, sortedBC1, sortedBC2, averagingIntervalInMinutes) wave sortedTimeOfDay // Time-of-day wave wave sortedBC1, sortedBC2 // Concentrations wave variable averagingIntervalInMinutes // Interval over which to average in minutes; e.g., 60 for 1 hour variable numBins = (24 * 60) / averagingIntervalInMinutes variable averagingIntervalInSeconds = averagingIntervalInMinutes * 60 //Number of columns of Statistical tables variable numStatsColumns = 12 // Variables to find the first and last point of each bin variable numInputPoints = numpnts(sortedTimeOfDay) variable i, bin, timeOfDay Variable BC1, BC2 // To find the median and standard deviation for each bin variable first variable last variable count variable median //-------------------------------------------------------------------------------------------// //-------------------- Make output waves of BC waves --------------------// //-------------------------------------------------------------------------------------------// //-------------------------------------------------- //-------------------- BC1 -------------------- //-------------------------------------------------- Make /O /D /N=(numBins,numStatsColumns) BC1Stats = 0 // 2D wave SetDimLabel 1, 0, Count, BC1Stats // Column 0 is count of concentrations in bin SetDimLabel 1, 1, First, BC1Stats // Column 1 is first input point in bin SetDimLabel 1, 2, Last, BC1Stats // Column 2 is last input point in bin SetDimLabel 1, 3, Min, BC1Stats // Column 3 is median concentration for bin SetDimLabel 1, 4, Max, BC1Stats // Column 4 is median concentration for bin SetDimLabel 1, 5, Mean, BC1Stats // Column 5 is mean concentration for bin SetDimLabel 1, 6, StdDev, BC1Stats // Column 6 is standard deviation for bin SetDimLabel 1, 7, Median, BC1Stats // Column 7 is median concentration for bin SetDimLabel 1, 8, Q25, BC1Stats // Column 8 is Quartil25 for bin SetDimLabel 1, 9, Q75, BC1Stats // Column 9 is Quartil75 for bin SetDimLabel 1, 10, upperInnerFence1, BC1Stats // Column 10 is for bin SetDimLabel 1, 11, lowerInnerFence1, BC1Stats // Column 11 is for bin // Set X scaling such that the statistics for each bin fall in the middle of bin when graphed SetScale/P x, averagingIntervalInSeconds-3600, averagingIntervalInSeconds, "dat", BC1Stats // Preset columns of output BC1Stats[][%first] = -1 BC1Stats[][%last] = -1 // Find the first and last point of each bin, and count for (i=0; i<numInputPoints; i+=1) // Bin and sum up the concentrations timeOfDay = sortedTimeOfDay[i] bin = trunc(timeOfDay / averagingIntervalInSeconds) if (BC1Stats[bin][%first] == -1) BC1Stats[bin][%first] = i endif BC1Stats[bin][%last] = i if (numtype(BC1) == 0) // Exclude NaNs and INFs BC1Stats[bin][%count] += 1 // Increment bin count endif count = BC1Stats[bin][%count] endfor // Find the minimum for each bin BC1Stats[][%min] = WaveMin(sortedBC1, BC1Stats[p][%first], BC1Stats[p][%last]) // Find the maximum for each bin BC1Stats[][%max] = WaveMax(sortedBC1, BC1Stats[p][%first], BC1Stats[p][%last]) // Find the mean, median and standard deviation for each bin for(bin=0; bin<numBins; bin+=1) first = BC1Stats[bin][%first] // First input point for this bin last = BC1Stats[bin][%last] // Last input point for this bin Duplicate /R=[first,last] /FREE sortedBC1, temp1 // Needed because StatsMedian works on the whole wave WaveTransform zapNaNs, temp1 // Needed because StatsMedian does not support NaNs median = StatsMedian(temp1) BC1Stats[bin][%median] = median // WaveStats /M=2 /Q temp1 WaveStats/Q temp1 BC1Stats[bin][%mean] = V_avg BC1Stats[bin][%stddev] = V_sdev StatsQuantiles/Q temp1 BC1Stats[bin][%Q25] = V_Q25 BC1Stats[bin][%Q75] = V_Q75 Variable H1=V_Q75 - V_Q25 Variable step1=1.5*H1 Variable upperInnerFence1=V_Q75 + step1 Variable upperOuterFence1=V_Q75 + 2*step1 Variable lowerInnerFence1=V_Q25 - step1 Variable lowerOuterFence1=V_Q25 - 2*step1 BC1Stats[bin][%upperInnerFence1] = upperInnerFence1 BC1Stats[bin][%lowerInnerFence1] = lowerInnerFence1 endfor //-------------------------------------------------- //-------------------- BC2 -------------------- //-------------------------------------------------- Make /O /D /N=(numBins,numStatsColumns) BC2Stats = 0 // 2D wave SetDimLabel 1, 0, Count, BC2Stats // Column 0 is count of concentrations in bin SetDimLabel 1, 1, First, BC2Stats // Column 1 is first input point in bin SetDimLabel 1, 2, Last, BC2Stats // Column 2 is last input point in bin SetDimLabel 1, 3, Min, BC2Stats // Column 3 is median concentration for bin SetDimLabel 1, 4, Max, BC2Stats // Column 4 is median concentration for bin SetDimLabel 1, 5, Mean, BC2Stats // Column 5 is mean concentration for bin SetDimLabel 1, 6, StdDev, BC2Stats // Column 6 is standard deviation for bin SetDimLabel 1, 7, Median, BC2Stats // Column 7 is median concentration for bin SetDimLabel 1, 8, Q25, BC2Stats // Column 8 is Quartil25 for bin SetDimLabel 1, 9, Q75, BC2Stats // Column 9 is Quartil75 for bin SetDimLabel 1, 10, upperInnerFence2, BC2Stats // Column 10 is for bin SetDimLabel 1, 11, lowerInnerFence2, BC2Stats // Column 10 is for bin // Set X scaling such that the statistics for each bin fall in the middle of bin when graphed SetScale/P x, averagingIntervalInSeconds-3600, averagingIntervalInSeconds, "dat", BC2Stats // Preset columns of output BC2Stats[][%first] = -1 BC2Stats[][%last] = -1 // Find the first and last point of each bin for (i=0; i<numInputPoints; i+=1) // Bin and sum up the concentrations timeOfDay = sortedTimeOfDay[i] bin = trunc(timeOfDay / averagingIntervalInSeconds) if (BC2Stats[bin][%first] == -1) BC2Stats[bin][%first] = i endif BC2Stats[bin][%last] = i if (numtype(BC2) == 0) // Exclude NaNs and INFs BC2Stats[bin][%count] += 1 // Increment bin count endif count = BC2Stats[bin][%count] endfor // Find the minimum for each bin BC2Stats[][%min] = WaveMin(sortedBC2, BC2Stats[p][%first], BC2Stats[p][%last]) // Find the maximum for each bin BC2Stats[][%max] = WaveMax(sortedBC2, BC2Stats[p][%first], BC2Stats[p][%last]) // Find the median and standard deviation for each bin for(bin=0; bin<numBins; bin+=1) first = BC2Stats[bin][%first] // First input point for this bin last = BC2Stats[bin][%last] // Last input point for this bin Duplicate /R=[first,last] /FREE sortedBC2, temp2 // Needed because StatsMedian works on the whole wave WaveTransform zapNaNs, temp2 // Needed because StatsMedian does not support NaNs median = StatsMedian(temp2) BC2Stats[bin][%median] = median // WaveStats /M=2 /Q temp2 WaveStats/Q temp2 BC2Stats[bin][%mean] = V_avg BC2Stats[bin][%stddev] = V_sdev StatsQuantiles/Q temp1 BC2Stats[bin][%Q25] = V_Q25 BC2Stats[bin][%Q75] = V_Q75 Variable H2=V_Q75 - V_Q25 Variable step2=1.5*H2 Variable upperInnerFence2=V_Q75 + step2 Variable upperOuterFence2=V_Q75 + 2*step2 Variable lowerInnerFence2=V_Q25 - step2 Variable lowerOuterFence2=V_Q25 - 2*step2 BC2Stats[bin][%upperInnerFence2] = upperInnerFence2 BC2Stats[bin][%lowerInnerFence2] = lowerInnerFence2 endfor End
):Btw. this function downsamples the incoming data to halve the points in the process.
July 2, 2015 at 04:04 am - Permalink
Resample
.July 2, 2015 at 04:12 am - Permalink
July 2, 2015 at 05:51 am - Permalink
July 2, 2015 at 03:20 pm - Permalink
The waves come from an Aethalometer instrument, so I have seven black carbon waves (BC1, BC2, ..., BC7). The function CalcConcStats_BC_Test() calculates the statistics of each wave.
I am going to try what you wrote me, I hope it works!
Thanks again!
July 3, 2015 at 12:19 am - Permalink
