Igor crashes saving wave as .itx (Igor Text Format)
tweed
I've attached an experiment with a problem I am having.
Namely, I want to save out a 1D wave in Igor Text format. I can save it out in tab-delimited format fine, but when I try to save the same wave in Igor Text format, it *does* save out, but Igor crashes immediately after saving the file.
If you Run "Main()" in the command line, you will see an example: the wave is saved as tab delimited, there is a pause, then Igor saves out the wave and crashes.
I've also attached the (long) operating system error report. For what it is work, I am running OS X 10.9
Any advice would be helpful!
By the way, this much of your crash report is relevant:
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.wavemetrics.igorpromach 0x00423929 Slash + 73
1 ??? 0x72616573 0 + 1918985587
and it shows that Igor was well and truly trashed!
July 1, 2015 at 01:31 pm - Permalink
July 1, 2015 at 02:34 pm - Permalink
I get the crash in 6.35A5 but not in 6.37. So I think you just need to update. Choose Help->Updates for Igor.
July 1, 2015 at 11:06 pm - Permalink
July 2, 2015 at 07:33 am - Permalink
