Question about loading delimited text file
Maarten1
My experiment delivers results in delimited text files, such as the one attached. When I try to load the waves, I can set the column name line and the first data line in the tweaks. All fine, but when I then load the file, every other line is empty. Igor must be triggered by a carriage return somewhere or something? Does anyone have a solution for me?
I am running Igor 6.36 on Windows 7.
Thanks!!
To see this, execute the following in a new experiment:
The scroll down to point 361. You can also use Edit->Find to search for 13. You will see that the header lines are OK but the data lines have an extra CR.
It would be best to fix this in the program writing the file. Otherwise you can remove the blank lines using WaveTransform zapNaNs.
June 8, 2015 at 12:24 pm - Permalink
Can you change the data saving routine and change it to "CRLF" or just "CR"? Old data files can be conveniently altered by a 'better' text editor like notepad++. If necessary in all files in a directory including sub-directories with a few clicks.
Igors "Load waves >" feature is able to load the data using "Tweaks", but ends up with NaN for every second data point.
HJ
PS: My computer died from excessive parallel computing and I had to restart it. Session was saved but I was late.
June 8, 2015 at 12:52 pm - Permalink
June 8, 2015 at 09:58 pm - Permalink
