Covariance matrix in multipeak fitting 2.0
Silvia Di Fonzo
I am running multifit peak 2 with voigt peaks applied to some Raman spectra and I I would like to study the parameter correlations among the different peaks-
is there a way to get values for the covariance matrix out of multifit peak 2.0 ?
Thank you
You could add it- make a copy of the file Multi-peak Fitting 2.ipf (so that you don't modify the shipping version) and add /M=2 flag to the FuncFit command you find in the procedure file.
May 19, 2015 at 09:34 am - Permalink
